Bonneville GXP and Bonneville headlight differences Help!
cjbennett01
Year and Trim: 2005 Pontiac Bonneville GXP
Post by cjbennett01 »
Can someone tell me if there is a structural difference in the replacement head light housing assemblies on a 2005 Bonneville GXP versus a regular Bonneville? GXP headlights are like 700.00 per pair in comparison to 300.00 per pair regular Bonneville headlights. I am debating buying regular headlights heating them in the oven softening the adhesive to remove the lenses and place them on my original housings. Thoughts? Thanks in advance
CMNTMXR57
Re: Bonneville GXP and Bonneville headlight differences Help
Post by CMNTMXR57 »
Nope. Just a smoked lens and use of HIR bulbs in the high beams.
2011 Camaro SS
crash93ssei
Post by crash93ssei »
The outer lens itself is the same except the lettering for what bulb the headlight uses, that will not make any difference though. You can definitely swap lenses out.
I would recommend trying this first though instead of buying new headlights if yours are just oxidized and nasty looking... http://www.pontiacbonnevilleclub.com/fo ... 37117.html
crash93ssei
CMNTMXR57 wrote:Nope. Just a smoked lens and use of HIR bulbs in the high beams.
The lens isn't smoked.
GXP - flat black glare caps
Standard - chrome glare caps
GXP - reflector housing around blinker is glossy black
Standard - reflector housing around blinker is chrome
GXP - HIR bulb for high beam, low is standard halogen
Standard - standard halogen bulbs for low and high beam
GXP - reflector housing for high and low beams is a slightly darker chrome
Standard - reflector housing is bright chrome
The actual lens itself is basically the same between the lights with the only difference being the GXP lens has HIR molded in the bottom of the lens face for the bulb, which is something that nobody would ever notice.
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
This. Ryan and I verified it last summer! :)
Bvill_GXP
Post by Bvill_GXP »
It really didn't matter to me bc I'm tired of cleaning my headlights every month lol! And I'm going to get some standard headlights and if its that much of a difference and I can't deal with it ill just pop em in the oven and swap lens!
2005 Bonneville GXP Fully Loaded
crash93ssei
Don't waste your time, just swap the lens, but I really recommend trying what I posted above first.
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
What do you mean by "cleaning...once a month". Id hope you clean the car more often than that. It sounds like you need to wetsand them down to get rid of the damaged layer of plastic.
CMNTMXR57
Post by CMNTMXR57 »
A month actually isn't all that long! Outside of winter months when road salt is down, It's been a month since I washed the Caddy. It just doesn't get dirty. Maybe a little dust on it, but...
2011 Camaro SS
SSEiMan01
Post by SSEiMan01 »
Unless your car sits outside and you don't have a Suburban to drive in the rain. :P :poke:
James May wrote:Hello.
CMNTMXR57
Post by CMNTMXR57 »
Sits outside 24/7. IT gets rained, hailed, snowed on, just like the van and the Suburban.
2011 Camaro SS
Andacious
Post by Andacious »
This info was helpful almost 10 years later. I am considering buying base model headlights for the following reasons:
1. The lenses constantly haze over, even after sanding them down and polishing them. The lens plastic seems to be failing as it is also filled with micro-cracks.
2. HIR lights (9011/9012) never really "took off". No reputable manufacturer makes low-profile 9011 LED headlights for the GXP high beams. I stuffed 9005 LED's in them for now, but the fit and beam pattern are not correct.
3. 05 GXP headlight assemblies are hard to come by, and are expensive.
So it seems that the base model assemblies are the best bet here; I can have clear lenses and LED's for low and high beams.
You can very easily replicate GXP lights by taking them apart and spray painting the glare caps and corner reflectors with black engine enamel. I've done it numerous times.
Keep your headlights waxed and/or sealed and they will last a lot longer before hazing over. I used TYC replacements nearly 4 years ago and they still look great.
