Supercharger snout pulley needs to be replaced
Posted: Fri Mar 01, 2013 5:24 pm
by zvega88
For a little bit now i have heard this noise coming form the engine and we know its the pulley that is connected to the snout. I am wondering if there is a place where they sell the pulley by itself to replace it. Also any other ideas will be welcome too.
Re: Supercharger snout pulley needs to be replaced
Posted: Fri Mar 01, 2013 5:29 pm
by CMNTMXR57
Intense, ZZP, and probably a few others that have smaller Hi-po versions including a modular setup. Otherwise, GM sells them...
I don't think I have any of mine anymore.
Posted: Fri Mar 01, 2013 5:47 pm
by harofreak00
ZZP sells the stock 3.8" pulley for $10.
However, I guarantee that nothing is wrong with the actual pulley. It's either the snout bearings or the rotor bearings. Cheapest to just replace the SC.
Posted: Fri Mar 01, 2013 6:03 pm
by CMNTMXR57
My first question was going to be "did you check the S/C oil to see if there was any in there" figuring a bearing failure would be due to oil loss or high load on the snout, but figured I'd just answer the question.
Posted: Mon Mar 04, 2013 11:56 pm
by zvega88
Few months ago I filled up the oil for the SC but the noise keeps going. So im not sure what it is. When i put some WD 40 on the side of the pulley it stops the noise for few minutes but then it goes back again.
