Gremlins in my cluster.....
Bl4z3
Year and Trim: 2025 NONYA
Post by Bl4z3 »
=D>
CMNTMXR57
Re: Gremlins in my cluster.....
Post by CMNTMXR57 »
If it's pinned, it's electrical meaning an open in the circuit somewhere as it's reading "infinite" resistance. If it's electrical, it's usually one of two things. The ECT sensor or the stepper motor in the cluster. GM calls for IPC replacement, but sme here will just replace parts internally.
Many in this section (as well as Bonneville's in general), have had similar issues. It could be the wiring too, but usually it's one of the others.
2011 Camaro SS
cliftonjim
Year and Trim: 2005 Pontiac Bonneville GXP
Post by cliftonjim »
Exactly the problem my wife had with my 2005 GXP, while In FL a number of years ago. Eventually, the temp gauge kept failing regularly, and then the fuel gauge started fluctuating. Last year had the entire cluster replaced, unfortunately outside the warranty. All has been well since then.
RJolly87
Post by RJolly87 »
I believe the DIC throws a message once it starts getting past 260 on the SSEi's. Not sure why GXP would be any different. Can you check coolant temp on the DIC?
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
You can get a scantool on the car to confirm the temperature reading matches that of the gauge, but my hunch is that the cluster stepper motors have failed. This is a common failure for many mid 2000's GM vehicles - not just the Bonneville. There are many websites who will replace all bulbs and motors in your cluster for anywhere from $100 to $120, and have a quick turnaround. You just have to ship it to them (you can still drive your car without a cluster if you need to). If you're daring enough and are good with soldering/electronics, X25.168 stepper motors can be found on eBay.
The DIC should also warn you if the car is in overheat territory, though the exact temperature threshold escapes me
CosmicVagabond
Year and Trim: 2005 Bonneville GXP (Bone Stock)
Post by CosmicVagabond »
Is there a tutorial on how to remove the cluster? I'd like to take mine out and ship it off to have the motors replaced.
repinS
Moderator
Moderator
Post by repinS »
There's a reply in your thread posted back in December: http://www.pontiacbonnevilleclub.com/fo ... 36714.html
CosmicVagabond
Thanks!
Bl4z3
Post by Bl4z3 »
=D>
CMNTMXR57
Post by CMNTMXR57 »
So it can't get it up? ;)
2011 Camaro SS
repinS
Moderator
Moderator
Post by repinS »
Repair, don't replace. That is 100% rebuildable.
