TRANSGO SK-4T65E Kit
Posted: Sun Dec 16, 2012 3:12 pm
by roadtested
Are "new" seals for the 1-2 & 3-4 accumulator pistons included with the kit? There seems to be some confusion as to the content of the kit. Any "torn" gasket reports for the accumulator housing to cover? Aside from adding the second magnet and a drain plug that's pretty much the extent of everything that can be accomplished without dropping the side cover and suspension member for modifications,correct?
Yes or no to Seafoam or similar product for maybe a 100 mile drive before the service? Which product might be the preferred? Dexron VI?
Any comments?
Thanks!
Re: TRANSGO SK-4T65E Kit
Posted: Sun Dec 16, 2012 10:34 pm
by flatlander745
No seals for the pistons, just the springs and spacers. When I did mine the gasket wanted to stick but it came apart fine. I would stick with Dex III because VI is thinner and would not help the "seal" in the piston walls.
Posted: Mon Dec 17, 2012 4:19 am
by roadtested
flatlander745 wrote:No seals for the pistons, just the springs and spacers. When I did mine the gasket wanted to stick but it came apart fine. I would stick with Dex III because VI is thinner and would not help the "seal" in the piston walls.
It's been my understanding that it's not long and the "shear" of D-III is actually less than D-VI. I was actually planning on Allison TranSynd but I ran a little short on time and purchased the D-VI. Maybe I'll rethink the wait!
TranSynd:
http://www.allisontransmission.com/service/transynd.jsp &
http://www.allisontransmission.com/docu ... /1099B.pdf
You didn't pass on any thoughts of the Seafom or equivalent for a hundred or so miles!
Posted: Mon Dec 17, 2012 10:04 pm
by flatlander745
I've only used Seafoam in the gas tank and for intake hot soak. I have always been resistant to put it in the crankcase or trans and haven't really heard results of anyone who has. Prob a good Google search for that one.
Posted: Tue Dec 18, 2012 12:18 am
by roadtested
I assumed that most would be familiar with the Trans Tune by Seafoam:
http://www.seafoamsales.com/how-to-use-trans-tune.html
I certainly didn't believe anyone would assume I meant the "crankcase" product!
Posted: Tue Dec 18, 2012 10:28 am
by flatlander745
Lol, just a general response, you can use the regular Seafoam in the crankcase before an oil change.
Posted: Tue Dec 18, 2012 12:23 pm
by Archon
I generally run the Trans Tune before doing a pan drop and filter change.
