Page 1 of 2
1st time Bonnie owner
Posted: Mon Nov 05, 2012 9:56 pm
by rrings
Just bought my 1st Bonneville, a 2001 SSEi 150k on the clock, one owner, very clean and well maintained! You guys let me know what to expect from her. She has new tires, struts and brakes, I gave a shade over 3000$ Did I do ok? What is the first thing to look for or is it just regular stuff? My first blown 3.8 ever!
Thanks, Russ
Re: 1st time Bonnie owner
Posted: Tue Nov 06, 2012 12:24 pm
by WhiteArrow3800
Should be a great car for you. Price wasn't bad at all. Welcome to the Club!
Posted: Tue Nov 06, 2012 2:58 pm
by nos4blood70
Welcome!
Posted: Tue Nov 06, 2012 3:44 pm
by PaulyGXP
If I were you... New oil, new supercharger oil, check/test the rest of the fluids for color and cleanliness. Check wheel bearings, stabilizer links, ball joints, shocks, and belts. Change spark plugs, wires, check air filter... you get the idea
Posted: Tue Nov 06, 2012 7:04 pm
by rrings
I'll get some pics up as soon as I can. Looks like regular maintenance is the key. What do you guys think about running premium fuel? I am planning on it anyway but was curious.
Thanks, Russ
Posted: Tue Nov 06, 2012 7:23 pm
by 2002FO
Welcome aboard... Loads of good info here, so search, search, search...
Posted: Tue Nov 06, 2012 7:33 pm
by 01bonneSC
ALWAYS RUN PREMIUM FUEL
and welcome!!!
Read this...
(I know its for N/A 3.8L but the LIM gaskets are what pertain to you)
http://www.pontiacbonnevilleclub.com/fo ... c1061.html
This...
http://dex-cool.net/
This....
http://www.pontiacbonnevilleclub.com/fo ... c3591.html
And this...
http://www.pontiacbonnevilleclub.com/fo ... 25362.html
This....
00Beast wrote: :beerchug:
  • 1987-2005 Bonneville / Buick 3800 Maintenance List
    Run Seafoam, Chevron Techron or Gumout Regane through gasoline every 5,000 miles.
    Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease or Amsoil Grease recommended)
    PCV Valve Every 30k
    Fuel Filter Every 15-25k (Purolator, AC Delco, WIX) http://www.pontiacbonnevilleclub.com/fo ... 45&t=23215
    Spark Plugs Every 30-50k (NGK TR55, AC Delco 41-101 or Autolite 605) (Never Bosch)
    Oil & Filter Every 5-6k or Every 6 months (Valvoline SYNPower, Pennzoil Platinum, or Amsoil )(Mobil1, Purolator PureONE, Amsoil EaO, K&N or WIX) (Never Fram) viewtopic.php?f=45&t=214
    *Conventional Oil Every 3k/3 months(API SM/SN rating) (WIX (Napa), Delco or Purolator filter)
    Tires: Check Inflation Pressure & Visually Inspect Monthly Rotate Every 6-8,000 Miles
    Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) viewtopic.php?f=45&t=10193
    Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Mixes-With-Any Coolant Only) (Never Dexcool)
    Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only) viewtopic.php?f=45&t=13626
    Brake Fluid Flush 3yr/50k
    Power Steering Fluid Replacement/Flush Every 100k or 5 years
    *Special Considerations*
    All Series II/III 3800's RPO's: L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
3/2/12 by 00Beast
Good info here...
http://3800supercharger.net/
And THEN you can read this...
http://www.pontiacbonnevilleclub.com/fo ... 25655.html
Posted: Wed Nov 07, 2012 8:19 pm
by rrings
Wow! thanks for the info, its like a Bonnie bucket list!
Posted: Wed Nov 07, 2012 8:27 pm
by SSEiMan01
Yeah what they said. Also, make sure to check everything underneath your car, like steering and suspension wise. Just four days ago I had a sway bar link break in half due to rust on that part. My car's pretty young for an 01, but still, better safe than sorry.
Welcome to the madness! :)
Posted: Wed Nov 07, 2012 8:33 pm
by Bl4z3
:beerchug: Welcome! Can't wait to see the pics!
Posted: Sun Nov 25, 2012 2:22 pm
by wake
Welcome fellow Illinois member, yes always run premium!
where ya from? :poke:
Posted: Tue Nov 27, 2012 6:57 pm
by rrings
Nauvoo, Il and I got some pictures up in the pics forum!
Posted: Tue Nov 27, 2012 7:12 pm
by wake
way out there on the edge by the Mississippi river huh?
pretty good looking bonneville you have there :beerchug:
Posted: Sat Dec 01, 2012 5:14 pm
by rrings
I live just off the mississippi river. It's about 3 miles straight west and 4 miles straight north. I drove close to your stompin grounds to get my Bonnie. It was in Tinley Park IL.
Posted: Sat Dec 01, 2012 5:42 pm
by SSEiMan01
rrings wrote:I live just off the mississippi river. It's about 3 miles straight west and 4 miles straight north. I drove close to your stompin grounds to get my Bonnie. It was in Tinley Park IL.
I live in Orland Park!! That's the town right next to Tinley! Which dealer??
I'm at school in Bloomington-Normal right now. :lol:
Posted: Sat Dec 01, 2012 5:45 pm
by SSEiMan01
Wait a second... I looked at the pics. I'm pretty sure I recognize that car... Did you buy it from a private seller on Harlem Ave at about 183rd street??
Posted: Sun Dec 02, 2012 2:07 pm
by wake
next time your up this way be sure to post it before hand :btruestory: :banana:
Posted: Sun Dec 02, 2012 11:17 pm
by rrings
Yes! off of Harlem Avenue close to 183rd. Right off the Interstate. Found it on Craigslist.
Posted: Mon Dec 03, 2012 10:27 am
by SSEiMan01
Wow! I knew it looked familiar... I looked at that car once. I drive past that intersection all the time on my way to and from B-N. I knew it when I saw you had to buy new center caps, cause there was only like one 01 cap on it, and I recognized the bra. (I assume it is covering hood herpes.) Good deal either way though! Cleaned up great! :)
Posted: Mon Dec 03, 2012 3:04 pm
by ricosuave420
glad to hear you joined the club, ive had a 1993 ssei since the day it rolled off the assembily line, and we still love it to death, just letting you know you are going to love your bonneville
