ARP Head Stud Leak
Posted: Mon Aug 27, 2012 7:08 am
After rebuilding my L67 SII, and running it probably 30 minutes total I've been going over various leaks. The major one of concern is a head stud leaks coolant, located at the firewall bank outside of head, closest to the passenger side. It leaks very little, but its a leak that I don't want. I used ARP lube in the assembly, which I thought was going to seal it, but apparently not, others have reported that it doesn't as well, which in hind sight, I should have done my research.
Two things, how do I go about fixing this? I know I need to add an RTV like sealant but is it possible to remove the 1 culprit, add the sealant and then torque the 1 stud. Or does the SC and LIM need to come off to loosen all studs and then re-torque all?
Also do any of the studs that are seated in the head run through a coolant passage? Or does anyone know exactly which ones do? If I recall correctly when assembling, the studs inside the heads looked to all pass all the way through to above the crank, which would indicate they wouldn't hit a coolant passage.
