Brake rotor removal
nbro3546
- Year and Trim: 1997 Pontiac Bonneville SSEI
Brake rotor removal
I'm trying to put new rotors and pads on my 97 ssei and I can't seem to figure out if the rotor is rusted on or what. It wont come off and figured I'd post here before destroying the cv axle or some shyt. Need Advice Please!
- J Wikoff
- Year and Trim: 1992 SSE
Re: Brake rotor removal
If you have any penetrating fluid like PB blaster, spray it around the center hubs, where the studs come through the rotor, and around back into the "hat" around the hub.
- Archon
Strike the face of the rotor between the studs, moving around the rotor from side to side. Be careful not to hit the studs and mess up the threads. It may take a while, but eventually it will work loose. You could spray some penetrant around the hub in the center to help things along.
nbro3546
Yea I'm doing that now (yay PB blaster!). Just making sure the hub or axle is not pressed into the rotor b/c it seems to really be on there.
- Pair of SSEI
- SSEi Member
- Year and Trim: 1997 SSEI 40th
Before putting rotor back on clean up the hub/axle with some steelwool.
1997 SSEI 3.8 L67 149,000 miles Moonroof, Polished Gen V w/L32 intake, 3.5 mod. Pulley, SD Headers, Intense Stage 1 tune, MagnaFlow Cat 94109, Catco catback, Autolite 103s, 180 stat, Intense FWI, 1995 OEM trans cooler, Cleared corners. KYB Excel G struts and shocks.
2006 Malibu SS 3.9 60 degree V6, Variable Valve, Tap shift Trans, 100,000 miles Bone stock
SOLD - 1992 SSEI FWI PEM Catco Cat NGK TR55 180 stat Original owner 209,000 miles Original Engine and Trans - Still strong when she left
- GMC Guy
- Posts like an LG3
- Year and Trim: 1999 Bonneville SSEi
I usually put some antiseize on the area around the hub and the studs where the rotor touches to avoid having this happen.
just my two cents
just my two cents
Tinted 13% Front 3% Rear, MSD Coils and Wires, K&N drop in air and oil filter...more to come as things wear/break!!
Tint it so dark, you won't even know your name
A long, narrow wire brush works well between the studs and on the hub, and anti-seize on the hub is a must.
