Tape deck
01ssei
Year and Trim: 2001 Pontiac Bonneville SSEI
Tape deck
Post by 01ssei »
Ok I realize its 2012 and cassette players are far outdated but I don't have an aux plug in my ssei so I'm trying to use a tape deck one and I put it in and the player spits it out the tape light comes on then it goes off... All I want to do is listen to my ipod without needing a new head unit any advice on fixing tape player?
redzmonte
Year and Trim: 2000 SSEI
Re: Tape deck
Post by redzmonte »
you can have a AUX port added. any sterio shop should be able to do that. im sure there is a harness with an adaptor that can be added retaining the stock deck with a AUX or a Ipod adaptor. I was just looking at them for my vette.
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
Night Crawler
Re: Tape deck
Post by Night Crawler »
This is what i use in my 02 se. Works great, you need to have a stereo that has the cd changer hook up on the back though
http://www.mp3yourcar.com/vehicle/PONTI ... ut/PXDXGM2
FWI, converted low beam bulbs into high beam bulbs, 20% tint all around, MSD wires, NDK TR55 plugs, auxiliary line in, scan gauge, custom FloPro/MagnaFlow Cat back exhaust
2002 Bonneville SE
