shaved engine bay?
- Adamus Prime
- Year and Trim: 2000 Bonneville SE/SC
shaved engine bay?
Anyone done it?
2000 Bonneville (S)SE(i) - L26/L32 "top swap" - VS cam - ported M90 - ZZP 3.4" pulley - ZZP PCM tune - INTENSE FWI - Port Matched intake/exhaust - ZZP Power Log Manifolds - ZZP "Stage 2" Trans - 2 1/2" full exhaust - SLP Muffler - Hubcaps
01bonneSC
Re: shaved engine bay?
You mean smoothed firewall? cant remove your engine bay lol.
Not that I know of new cars. Lots of hot rods do though.
- harofreak00
95nasta did it.
01bonneSC
What is a shaved engine bay?
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Do you mean a wire tuck? Re-routing the wiring so it's much less visible?
01bonneSC
Oh smoothing the bay? like hiding everything but the engine and trans?
- 95naSTA
- Year and Trim: 95 SLE
I shaved the rad support, both areas in front of the strut towers, and the strut towers.
I tucked all body electrical harnesses, brake lines, the battery (in the bumper), coolant res (in the fender), and kept abs (in the bumper).
I still have to finish tucking the engine harness though.
- Adamus Prime
I was talking wire tucks, firewall smoothing.
- 95naSTA
Then, yes besides the firewall. IMO the fuse box cover on the 92-99 looks better there than not. Otherwise the blower box would stick out of place.
