Any suggestions? 2000 SSEi
Posted: Sat May 05, 2012 2:07 pm
by thefredman54
Okay I have posted this problem once before. Car has a knock when I start it and while its at idle. Doesn't affect performance, or at least it doesnt seem too. Thought it was a bad injector, replaced injector on what seemed to be the bad one from ohm reading. Did not make a difference. Open to ideas and suggestions. Runs rough instead of smooth. Thanks
Re: Any suggestions? 2000 SSEi
Posted: Sat May 05, 2012 6:53 pm
by redzmonte
is it a knock in the engine? it could be a couple things causing it not to run right... I would try removing and cleaning the MAF and if you have a way to scan it check the maf opperation.. a bad MAF would cause it to run bad. MAF are kinda expencive (100ish bux new) so i would say check other things as well before throwing parts at it. I would check the plugs and wires... try unhooking them one at a time and see if the idle/studder changes... that will narrow it to a cylinder... from there you can determine if the plugs are shot, wires are shot, ignition coil is not working or working poorly. if thoes all check out then i would probably do a compression test on all cylinders to make sure its got good compression.. if that comes back low then it could be a bent valve (not to common) or bad rings.
Thats were i would start..
S
Posted: Sun May 06, 2012 2:11 am
by myfirstbonnie
Please keep this in the same thread:
viewtopic.php?f=18&t=32573
Posted: Tue May 08, 2012 3:50 pm
by thefredman54
got it figured out thanks for the help everyone
Posted: Tue May 08, 2012 9:46 pm
by Mark Fahey
It's always good to give as well as receive as in help for the next person. What was the solution?
