Removing Wiper Arms
Posted: Wed May 02, 2012 6:44 pm
by PLAGUE PHANTOM
I am replacing my factory wiper arms and I am having some trouble removing them. I am replacing them because they are rusted and bent. How do I remove the wiper arms?
Re: Removing Wiper Arms
Posted: Thu May 03, 2012 1:42 pm
by imidazol97
PLAGUE PHANTOM wrote:I am replacing my factory wiper arms and I am having some trouble removing them. I am replacing them because they are rusted and bent. How do I remove the wiper arms?
I used a Lisle wiper arm remover/battery terminal remover.
Other people said just tapping, etc., would remove them. I didn't want to damage the pivot bearing area, so I bought the Lisle because the tips of the gripping fingers were thinner and would fit into the opening under the wiper arms.
The Cobalt wiper arm remover I have wouldn't fit under and grip the arm to break it loose from the bolt.
Posted: Fri May 04, 2012 6:17 pm
by sonoma_zr2
There is a small metal tab at the "base" of the wiper arm that has to be pulled to remove the tab from a slot in the drive shaft of the wiper. Then it is just to pull straight out.
Posted: Sat May 05, 2012 4:49 am
by Pontiac1
Lift the wiper arm to allow the locking tab to release,then as Sonoma mentions it should lift right off.
Posted: Sat May 05, 2012 10:52 am
by PLAGUE PHANTOM
Well I got then off but it required a pry bar to get them off. The driver side arm was destroyed. All the teeth in the mounting bore were stripped all to hell.
