Milkshake anyone? UPDATE 3-29-12 *fixed*
Posted: Mon Mar 26, 2012 1:34 pm
by Boss455
Re: Milkshake anyone?
Posted: Mon Mar 26, 2012 1:46 pm
by CMNTMXR57
Good gawd, that's nasty!
Posted: Mon Mar 26, 2012 2:53 pm
by crzydmnd72
And in a Venture. How tough are things to reach? Is this one you can remove dogbone on, and rotate engine toward you for service?
Posted: Mon Mar 26, 2012 3:34 pm
by Boss455
Not that bad, but yes, it's a pain to get at. Just alot of removing and such. I did rotate the engine forward with a strap to remove the alternator. The PS pump had to be removed as well. There's alot less room towards the firewall in a van but rotating forward gave me a few precious inches I needed. If you don't bleed, you didn't fix it.
Posted: Mon Mar 26, 2012 3:56 pm
by CMNTMXR57
Yea, you can "rotate" any GM FWD vehicle's engine for greater access...
Posted: Mon Mar 26, 2012 6:37 pm
by SSEiMan01
That is NASTY!!! I've not seen anything that bad since I did the IM gaskets on my 85's stock LB9.
Posted: Mon Mar 26, 2012 8:14 pm
by LeSabre in Buffalo
That's just icky. Hope the engine is running after that!
Posted: Mon Mar 26, 2012 9:13 pm
by yonkerse
How well was the van running before you ripped into it?
Posted: Tue Mar 27, 2012 4:04 am
by wake
thats plain out gross!
i sure hope you can get it running again after than mess!!
Posted: Tue Mar 27, 2012 10:32 am
by Boss455
She was running fine with no strange noises. I knew the gaskets were going bad and I was checking the oil regularly before it went milky. I'm gonna clean her up good and flush it a few times and hope for the best! Pray for me!
Posted: Tue Mar 27, 2012 2:25 pm
by Mad Myche
Everytime I read this thread I have flashbacks to working in quick-lubes and removing the oil fill / dipstick combo on the Chrysler 3.7L
Re: Milkshake anyone? UPDATE 3-29-12 *fixed*
Posted: Thu Mar 29, 2012 11:11 pm
by Boss455
She's alive! I fired her up but she ran badly until I figured out the ignition wires were messed up. The lifters ticked but that went away and no unusual noises so far. A few more oil changes and I think we're good!
Posted: Thu Mar 29, 2012 11:15 pm
by SSEiMan01
Hot rod van has 10 extra HP now for a red intake mani and valve cover!
Good work! Lifter tick at first isn't abnormal, just takes a second to circulate all around.
Posted: Fri Mar 30, 2012 7:51 am
Awesome! I wish the two 3400's in the family were that clean. They're both headed to the scrapyard in the next year or so due to rust on the van bodies.
Posted: Fri Mar 30, 2012 8:07 am
by MattStrike
It fun when you do a full rebuild on one of these 3400's and the lifter tick does NOT go away...
Posted: Fri Mar 30, 2012 8:11 pm
by RogueSSEi
Milkshake...lol butterscotch flavor. After pictures looking good.
Posted: Fri Mar 30, 2012 10:27 pm
by Backhoe
Looking' good Ray, I don't envy that engine bay one bit. I really should stop procrastinating and get on with doing mine, now that the weather is turning nicer.
Posted: Fri Mar 30, 2012 10:33 pm
by vogie01
http://www.youtube.com/watch?v=cawybukIPVg
Giggity!! Your thread made me think of this.
