headers; are they worth it!
deano55
- Posts like an L36
- Year and Trim: 2003 Bonneville SSEI
After much reading on here and other sites I'm questioning the idea of even putting headers on. I think its ZZP that sell the front custom exhaust manifold and claims a dyno hp increase of 10-11hp. Header manufacturers claim 8-15 hp. So with the average steet car that's not going after 400hp would it not be best to go with the custom manifold, big down pipe and big cat to go along with a good tune, fwi and a 3.8 and ofcourse plugs and stat?
- gonzo4191
- Year and Trim: 91 S10 P/U
97 SSEI- 136k - Location: round lake beach, IL
Re: headers; are they worth it!
if your goals are not to build an 12 sec car. a home ported from manifold and DP/cat combo is good. Although a cheap set of headers can be bought and you dont have to worry about it.
- yourgrandma
- Year and Trim: '02 SSEi
Zzp priced headers, no. Hp/$ is pretty bad.
I can't say what my headers did on their ow because I did a few things at once, but they sound cool, look cool and make changing plugs easier.
deano55
- Posts like an L36
How much of a loss of gas mileage did you have?yourgrandma wrote:Zzp priced headers, no. Hp/$ is pretty bad.
deano55
- Posts like an L36
It seems easier to change out the front manifold, down pipe and cat then doing headers and trans dipstickgonzo4191 wrote:if your goals are not to build an 12 sec car. a home ported from manifold and DP/cat combo is good. Although a cheap set of headers can be bought and you dont have to worry about it.
01bonneSC
If you do the PLog you need to skew the front injectors.deano55 wrote:It seems easier to change out the front manifold, down pipe and cat then doing headers and trans dipstickgonzo4191 wrote:if your goals are not to build an 12 sec car. a home ported from manifold and DP/cat combo is good. Although a cheap set of headers can be bought and you dont have to worry about it.
deano55
- Posts like an L36
What does this consist of?01bonneSC wrote:If you do the PLog you need to skew the front injectors.deano55 wrote:It seems easier to change out the front manifold, down pipe and cat then doing headers and trans dipstickgonzo4191 wrote:if your goals are not to build an 12 sec car. a home ported from manifold and DP/cat combo is good. Although a cheap set of headers can be bought and you dont have to worry about it.
01bonneSC
Getting the PCM tuned.
01bonneSC
- gonzo4191
I'm havin a meeting in april we can do that then if u want
deano55
- Posts like an L36
If I go this route rather than headers I will take you up on the offer. I just want to gather all you guys opinionsgonzo4191 wrote:I'm havin a meeting in april we can do that then if u want
- gonzo4191
Speed daddy headers I used. And tied it into the factory cat
back
back
deano55
- Posts like an L36
You chose headers rather than that manifold and down pipe, why?
- MattStrike
- Year and Trim: '99 Montana
Headers flow more than the stock manifolds can
deano55
- Posts like an L36
I'm not questioning stock manifolds, but rather ZZP custom manifoldMattStrike wrote:Headers flow more than the stock manifolds can
- yourgrandma
Headers are more effective for a modestly higher investment(assuming speed daddys).
As to the question of fuel economy, all else being equal, headers will make for more efficiency, thus better economy.
deano55
- Posts like an L36
Ok, I 'm seeing that the less expensive headers have only 1 1/2" primaries and the costly headers can have 1 3/4" primaries, it seems to me that 1 1/2" is too small especially if one was to do some porting on the heads.
- gonzo4191
if you go with sped daddys youll be fine.....
i just dont see a need to spend more for the same thing.....got my speed daddys for 202 shipped to my door!
01bonneSC
1 3/4 primaries are big block sizes. You WILL be fine with 1 1/2.deano55 wrote:Ok, I 'm seeing that the less expensive headers have only 1 1/2" primaries and the costly headers can have 1 3/4" primaries, it seems to me that 1 1/2" is too small especially if one was to do some porting on the heads.
What other mods do you have currently?
deano55
- Posts like an L36
o mods... thought I would start with FWI (intense) and headers and go from there01bonneSC wrote:1 3/4 primaries are big block sizes. You WILL be fine with 1 1/2.deano55 wrote:Ok, I 'm seeing that the less expensive headers have only 1 1/2" primaries and the costly headers can have 1 3/4" primaries, it seems to me that 1 1/2" is too small especially if one was to do some porting on the heads.
