New Floormats Came today
Posted: Thu Mar 01, 2012 9:13 pm
by 7tcatvert
Since my GXP did not come with floor mats decided to order a set from Lloyds...Here is what they look like...They dont seem to fit real well any one have a picture of the stock ones...FYI cost was 120 shipped......
Re: New Floormats Came today
Posted: Fri Mar 02, 2012 12:45 am
by SLOGXP
I worked at a dealership and use to order alot of mats with Lloyds. Very good quality mats. If they are not fitting correct Im sure they will take care of it for you. You can also make you own template out of paper and send it to them to make them just the way you want. Here are my original mats out of my 05 GXP.
If you want me to make a pattern for you Id be happy to.
Brian
Posted: Fri Mar 02, 2012 4:46 am
by 7tcatvert
See yours are different than what they sent....the driver side should have a cut out ...could you email me the picture also dimensions...my email is tq28 tz at aol.com...thanks
Tq
Posted: Fri Mar 02, 2012 5:39 am
by Bing
Don't post your e-mail address, theres spammers and what not love this kind of opportunity. Basically your last post could have been a PM sent to SLOGXP with your info and request. I'd edit out your address ASAP.
Posted: Fri Mar 02, 2012 11:40 am
by SLOGXP
You cn right click on the photo and choose save as. Ill post up dimensions tonight if I get home in time.
Brian
Posted: Fri Mar 02, 2012 10:26 pm
by 7tcatvert
I sent an email to LLyods with pictures and their response through Summit...
""""" Lloyd's contacted us regarding the issue with your floor mats not fitting. Their pattern for you vehicle is incorrect. They do not have the correct pattern at this time for the drivers side, so if we send you a replacement set is will have the same cut as the passenger side. They offered to re-cut and re-bind the mat you have if you can mark where it needs cut from the original factory mat. We can have this picked up for you and shipped to Lloyds if you are interested. Please let us know what you would like to do with the mat by responding to this email or contacting Customer Service at 800-517-1035.""""
So be careful if you order a set it will not be correct...both mats are for the passenger side......
Posted: Fri Mar 02, 2012 10:48 pm
by SLOGXP
Since one of them should work on the passenger side here is the drivers measurements:
Posted: Fri Mar 02, 2012 10:59 pm
by 7tcatvert
Thank you very much for your help.......
