How much boost does a stock M62 Gen III make?
Posted: Sat Jan 21, 2012 9:48 pm
by Drewster
Is is ok to T off of the Charcoal canister line to measure?
Andrew
Re: How much boost does a stock M62 Gen III make?
Posted: Sat Jan 21, 2012 11:56 pm
by J Wikoff
You can tap off any of the lines that come from the vacuum tree by the BCA.
Posted: Sun Jan 22, 2012 12:49 am
by Drewster
thats what i thought for the tap. i was seeing 2psi max at WOT. i thought that was really low. did come out of vacuum quick but i had expected around 7psi. i dont know what the M62 can put out. (vac was good at idle,18-20 in.hg)
Posted: Sun Jan 22, 2012 1:22 pm
by J Wikoff
There might be a leak in that line or the canister bleeds off positive pressure? Cap the line off to exclude the canister and try again. You should get about 7 psi. The gauge shows 0 when the engine's not running, right?
Posted: Sun Jan 22, 2012 1:40 pm
by willwren
Moving to the proper section.
There are some possible questions related to the fact that this is a swap:
1. Is your evap system tied in to the vacuum manifold as it was stock? This would be 'post inlet', not pre-inlet? Any boost indication would only be seen at the vacuum manifold closest to the nosedrive.
2. Is your BCA and BCS properly controlled and connected both in terms of vacuum and in terms of the BCS solenoid (electrical)?
3. What are you using to measure the 2psi of boost? Be specific, links if possible.
Test your BCA mechanically using the red link in my signature.
Posted: Sun Jan 22, 2012 2:50 pm
by Drewster
instead T ing into the Fuel Pressure Regulator sense line as shown in the links, i T'd into the next one up on the vac tree which is the Evap charcoal canister.
Boost control actutator tested on the bench before install and after intall solenoid was tested as per links and all looks proper
all vac lines are stock configuration. im seeing good vac
good posibility about the evap canister bleeding boost. i will check without the canister connected.
Confirming that i should see about 7psi boost.
Posted: Sun Jan 22, 2012 2:54 pm
by Drewster
i also used a vac/ 30 psi mechanical pressure gauge. i then added another pressure gauge to confirm my first gauge was proper. pulled vac with hand held tester on test rig to confirm no leaks.
ill post again after running without the evap canister line.
Posted: Sun Jan 22, 2012 3:08 pm
by willwren
If the BCA and BCS are working properly, and you don't have belt slip, it's physically impossible to have too little boost. It's not possible for a supercharger in our application to physically under-boost by itself. The only possibility is boost CONTROL. That comes down to the BCA function primarily. Boost indication may be another factor.
Posted: Sun Jan 22, 2012 3:30 pm
by J Wikoff
Good point about the BCS. Take the vacuum elbow off the bottom of the BCA and test your boost again. If it goes back up, check the wiring to the BCS. If the wiring is fine, replace the BCS.
Posted: Sun Jan 22, 2012 5:55 pm
by Drewster
looks like i had T'd into the line for the Trans modulator which also T's into the primary vacumuum block when i did my first test.
tested direct without the T and now showing 5psi and climbing to 6psi at the top of the RPMs.
ill also see if i get any more boost with the BCS bottom vac line off
thanks for the tips.
Andrew
Posted: Sun Jan 22, 2012 11:45 pm
by J Wikoff
You should get a few more psi than that. Stock gen 3 pulley, right? Any other mods? Roller rockers or anything else that helps move air in/out of the cylinders will lower the boost because there is less "boost stacking".
Posted: Mon Jan 23, 2012 11:01 am
by willwren
Adding your swap and mods to your signature would help us a ton.
