Tachometer 05 bonneville gxp
Posted: Fri Dec 30, 2011 4:33 pm
by gxpjim
Tachometer is showing 4000 + at normal 55mph driving! whats wrong?
Re: Tachometer 05 bonneville gxp
Posted: Fri Dec 30, 2011 5:03 pm
by SSEiMan01
Is the motor actually revving at 4k rpm? Or is it at the rpm it should be in O/D? That's the first question. If it is at normal rpm and showing the wrong rpm, a gauge cluster motor could have gone kaput. It's becoming more prevalent as our cars get older, although it is seen more on GM trucks than anything else.
Posted: Thu Jan 05, 2012 7:40 pm
by gxpjim
The engine is normal its the tach that is showing a higher than actual RPM.
Posted: Thu Jan 05, 2012 11:58 pm
by SSEiMan01
I would suspect you need a new cluster, I believe harofreak00 has one for sale.
Posted: Fri Jan 06, 2012 12:07 am
Otherwise you can have the stepper motor replaced by someone experienced with that. I do think that it's in the cluster, though.
Posted: Fri Jan 06, 2012 12:12 am
by SSEiMan01
My theory is, if one is going, the others may follow suit soon after, cheap insurance to replace the whole thing. IMO
Posted: Sat Jan 07, 2012 1:39 pm
by gxpjim
Thanks for the info regarding my Tachometer. I need to get it fixed, is it difficult for a mechanically inclined person to fix it?
Posted: Fri Feb 24, 2012 3:33 pm
by mende21
It's not bad if you're a patient, careful, mechanically inclined person. My oil pressure, temperature, and voltage gauges would get stuck, not move at all, or peg until I replaced the stepper motors. There are a few good youtube videos that show how to do it in other gm vehicles. You really need a solder sucker to remove the old ones and be very careful with the heat. I think I popped a light when I took my cluster out so replacing them all is the next chore.
