New intermediate shaft - is it better?
BestBonnieYet
Year and Trim: 2003 SSEi
Post by BestBonnieYet »
I have a 2003 SSEI with the annoying steering shaft rattle. I have greased, replaced, and replaced again the IS with no long lasting benefits. The local dealer told me they have another newer intermediate shaft - part no. 26056868. Does anyone know if this one is really better or solves the noise problem? I guess I'm not totally convinced that my IS is the culprit. I have no clunk turning the wheel but an agravating rattle over rough surfaces. Any input would be appreciated.
Last edited by BestBonnieYet on Sun Dec 25, 2011 12:53 pm, edited 1 time in total.
Archon
Re: New intermediate shaft - is it better?
Post by Archon »
The ISS generally makes a clunking noise while turning, and is silent while going straight. I'd look first toward something else in the suspension or steering...like endlinks, and tie rod ends.
5Bonnies
Year and Trim: 2004 Bonneville SLE
Post by 5Bonnies »
Yes. The new shafts are better. i put one in a 2000 Chevy Impala that my son was using. It really worked. I bought it from the local dealer for $121, but there are some dealerships who sell it on the web for less.
The kid's car sounded awful and it solved the problem. Will replace shaft on my '04 as soon as the grease wears off again.
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
On my Monte, the lower Ball joints made a clunk going over bumpy straight roads, not so much when turning. IF you veryify its the ISS then definatly get the updated one... the greasing technique is a bandaid gm came out with in a TSB before they decided it didnt cure the issue and redesigned the ISS. but definatly check the rest of the suspension before throwing parts at it.
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
2003BlackSapphireSLE
Year and Trim: 2003 Pontiac Bonneville SLE
Post by 2003BlackSapphireSLE »
BestBonnieYet wrote:I have a 2003 SSEI with the annoying steering shaft rattle. I have greased, replaced, and replaced again the IS with no long lasting benefits. The local dealer told me they have another newer intermediate shaft - part no. 26056868. Does anyone know if this one is really better or solves the noise problem? I guess I'm not totally convinced that my IS is the culprit. I have no clunk turning the wheel but an agravating rattle over rough surfaces. Any input would be appreciated.
You know I have an 03 sle. And when I first got it had an annoying rattle or chuckle over rough roads. I checked everything and even replaced the iss with the new design to no avail. I found information that came from a Cadillac forum that led me to check the lower steering column bearing. That is the bearing at the base of the column right before the iss starts. Its serviced as what they call a lower jacket or something and the column has to come apart. But that fixed it.
2003 Pontiac Bonneville SLE - Sylvania Silverstar Fog lights, 5000k HID conversion low beams, Disabled DRL, cranking headlight delay kit, GXP style exhaust tips, solid front mount. Approx. 86k miles and still kickin strong!
