UIMG, LIMG
Posted: Mon Dec 19, 2011 4:56 am
by samples08
Yup time to replace them can anyone give me some ideas on what would be the best to get for my moneys worth
Re: UIMG, LIMG
Posted: Mon Dec 19, 2011 5:43 am
by Bing
Pretty much the given is the APN UIM. This is the UIM that has the metal sleeved EGR passage. The Dorman kit isn't bad either but the UIM isn't sleeved at this critical spot. Both UIM kit's come with the reduced diameter EGR stove pipe though.
For the LIM gaskets go with the AcDelco aluminum ones, this will pretty much guarantee not having to do those for along time. What ever you do don't use the black plastic ones, they will fail again.
Not a bad time to look at doing the valve cover gaskets either.
Get rid of Dex-cool if your car still has it.
Fix anything else that is easy to get to while the motor is apart.
Re: UIMG, LIMG
Posted: Mon Dec 19, 2011 10:46 am
by steelmanwy
It's kind of hard to find that APN kit...there's a link in the how-to on here though.
Found it:
http://www.ineedparts.com/auto-parts/in ... 17806.html
Re: UIMG, LIMG
Posted: Mon Dec 19, 2011 11:04 am
by samples08
No Dexi-Cool Long gone! but thank you for the advice!
Re: UIMG, LIMG
Posted: Mon Dec 19, 2011 12:01 pm
by 01bonneSC
Be sure to read through the step by step in 'tech info'
