my 96 se sleeper
allanb
Year and Trim: 1996 se w/l67
my 96 se sleeper
Post by allanb »
[img]http://i113Image9.photobucket.comImage/albums/n541/allanbImagetn/Pic1111007.jpg[/IMG][img]http://iImage1139.photobucket.com/alImagebums/n541/allanbtn/Pic1111002.jpg[/IMG]Image/albums/n541/allanbtn/Pic11Image11005.jpg[/IMG]ms/n541/aImagellanbtn/Pic1111Image007.jpg[/img][img]http://i11Image39.photobucket.com/albumImages/n541/allanbtn/Pic1124001.jpg[/img]Image[/img]ImageImageImageImageImageImage
Re: my 96 se sleeper
Post by gonzo4191 »
that looks real nice....
they will tell you to get a fwi....
whats the mod list on the l67?
ga93sle
Year and Trim: 06 Grand Prix LS4
Post by ga93sle »
Wow, this one joined us already modded! Cool car!
*Chris*
15 Nissan Altima 2.5SL/2004 Honda Shadow 750 Aero
Previous, 07 GP SE, 06 GP GXP, 97 SSE 40th, 96 LeSabre Custom, 93 SLE, 90 LeSabre Custom
wake
Post by wake »
wow! nice SE you have there!!..please clean your cone filter :btruestory: :booty2:
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
Id lose your door badges, kinda defeats the purpose of it being a sleeper.
Yeah lose your HAI, Put your filter down in the bumper areas.
Not bad at all. Is that factory supercharged or did you add it?
Looks pretty good! The rims fit very well.
Although, as mentioned, you might wanna clean up that filter a bit. :poke:
And off topic question: shouldn't that heat shield isolate his intake enough or no? :dontknow:
Saturn Simon
Year and Trim: 1992 SSEi
Post by Saturn Simon »
Interesting.... I like! :)
SSEiMan01
Post by SSEiMan01 »
nos4blood70 wrote:Although, as mentioned, you might wanna clean up that filter a bit. :poke:
Not as much benefit as putting it out of the engine bay completely, it's better than some setups I've seen but not the best.
However, that car! I love the color!
@Ed, I'm guessing it's not factory...Doesn't seem like it is anyway. :dontknow: Judging by how the things on it are set up anyway...
James May wrote:Hello.
wake
Post by wake »
also forgot to mention, glad you put dual exhaust on it! :bwoohoo:
allanb
Post by allanb »
the cone filter (k&n) is clean, its only about 12yrs old and due for a new one. engine came from a buick ultra, trans and ecm came from a ssei. zzp 3.3 pully, 180 t-stat, colder plugs, accel 8.8 wires, accel coil packs, stainless steel headers, magnaflo highflow cat, 2.5" dual exhaust from 93 sse, high volume/pressure fuel pump. a cam and intercooler are in the future. it is the original color,was repainted last year after bad accident crushed driver side. had it since 01 and dont plan to ever get rid of it.
3.3 pulley?! :eek: Have you scanned for KR? You have to be making a bunch of it, even with headers.
I'd be wary of those Accel coils. Bunch of people have had issues with them. Nothing is wrong with the OEM S/C (blue tab) coils.
allanb
Post by allanb »
no kr that i know of,have not scanned for it. main problem that did have was under acceleration the added heat and pressure was to much for the oem coil packs to produce a spark causing random missfires, but not enough to cause check engine light. smaller spark plug gap and stronger coil packs solved problem. i have a 3.0 pully that i run some times with no problems
You cannot "feel" KR. You're doing damage to your motor running it with the 3.3, let alone the 3.0. It may pull hard and seem to run great, but your pistons and internals are being stressed beyond belief. Get a scanner on it ASAP.
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Nice SE!
Agreed, a $60 Chinese OBDII scanner is a must. Scan for knock, and make sure that sleeper doesn't go into a coma from popping a piston!
allanb
Post by allanb »
so what is the best remedy for it
allanb
Post by allanb »
i have a small cornwell obd2 scanner that i keep in the car if the engine light comes on
KR won't throw a code. KR is something you need to SCAN for, with a live-data scanner.
bigryan18
Year and Trim: 1997 Bonneville SE
Post by bigryan18 »
What rims are those???
Image Snow White
BonneMe
Post by BonneMe »
Chrome wheels, dual exhaust, and big red badging?
Not a sleeper....
Looks fun though! To be honest, i'd pick one set of badges, don't run both of them.
