Page 1 of 2
Sputtering problems
Posted: Thu Jul 03, 2008 7:17 pm
by Aaron88
I'm having a weird and I mean a weird problem lol. This problem just started almost 3 weeks ago with the car and only does it when it's between a half and a quarter of a tank of fuel it starts to sputter really bad and acts like it wants to cut off.The check engine light also comes on when this happens. When the car is filled up with fuel it does just fine and check engine light goes off. Anybody know what might be the problem?
Re: Sputtering problems
Posted: Thu Jul 03, 2008 11:31 pm
by imidazol97
Aaron88 wrote:I'm having a weird and I mean a weird problem lol. This problem just started almost 3 weeks ago with the car and only does it when it's between a half and a quarter of a tank of fuel it starts to sputter really bad and acts like it wants to cut off.The check engine light also comes on when this happens. When the car is filled up with fuel it does just fine and check engine light goes off. Anybody know what might be the problem?
My first guess would be the fuel filter and then the fuel pump may be weak.
Posted: Fri Jul 04, 2008 12:03 am
by Aaron88
I don't think it's the fuel pump. The fuel pump was replaced a few ago when my grandfather owned it. I will be sure to check the filter.
Posted: Fri Jul 04, 2008 2:34 am
by Aaron88
Guess what guys? I went to move the Bonneville just 2 mins ago back in the driveway and at almost a full tank she was doing the sputtering. I cut the car off and fired it back up again. It ran for a min back fired then cut off again. I fire it back up again and this time with my foot on the throttle and it blows some kind of crap out the exhaust pipe. After that it did fine so Idk. I still need to check the fuel filter. Oh and yea no check engine light came on this time.
Posted: Fri Jul 04, 2008 1:35 pm
by Jrs3800
Do you have any way to have the codes Pulled?
Posted: Fri Jul 04, 2008 3:31 pm
by Aaron88
Yes I do have a code reader. Where is the plug you hook it into located at on the car?
Posted: Fri Jul 04, 2008 5:09 pm
by Jrs3800
Look under the area of the steering column....
But is the code reader capable of reading the 94-95 GM Cars? These 2 years have a funky computer... And some tools will not read it... Also even tho the car has an OBD2 connector, it uses OBD1 protocol...
I almost think you may get a Code P0361 or a P1361 Depending on the Code Reader used
Posted: Sat Jul 05, 2008 12:21 am
by Aaron88
What do those codes mean?
Posted: Wed Jul 09, 2008 12:28 pm
by harofreak00
Aaron88 wrote:What do those codes mean?
http://www.pontiacbonnevilleclub.com/fo ... =51&t=1638
P1350/P1361- Ignition Control Circuit
Posted: Wed Jul 09, 2008 12:38 pm
by SSEi95
Aaron88 wrote: I cut the car off and fired it back up again. It ran for a min back fired then cut off again. I fire it back up again and this time with my foot on the throttle and it blows some kind of crap out the exhaust pipe.
Ny '95 did things exactly like that. The stuff coming out of the back was internals from my Cat converter (cat clogging up th eexhaust). You may be able to test this. Place a larger piece of cardboard or something right behind the exhast tips, and give it a few revs for a bit (not redlining, just maybe 2k or so). If it is the cat, you may, but not always, get some honeycomb shaped debis flying out the tail pipes. Might be worht a try to, since it is free and easy to do.
Posted: Wed Jul 09, 2008 12:41 pm
by harofreak00
Another test is to kick or pound on the cat under the car. If it rattles, its junk.
Posted: Wed Jul 09, 2008 7:31 pm
by Aaron88
I do hear some type of rattle on my exhaust system everytime I start it and when it idles. So that's probably the cat right?
Posted: Wed Jul 09, 2008 7:39 pm
by SSEi95
I'd still get underneath and bang on the cat directly, or do the trick I mentioned above. Loose heat shields and stuff can sound the same, but not actually be anything to worry about mechanically.
Posted: Wed Jul 09, 2008 9:08 pm
by Bugsi
Ditto on the cat. Had something very similar happen on my wife's `01 Grand Prix GT. It was the cat.
Let the cat out!
(Perfect excuse to put a Magnaflow cat on there now!)
-Mark
Posted: Thu Jul 10, 2008 3:37 am
by Aaron88
I think the car is gonna be needing a new exhaust system soon anyway. That one is still original and is now starting to rust bad.
Posted: Sun Jul 13, 2008 8:07 am
by chopperdave
I'll tell ya one thing first hand and that is CHECK THE CAT NOW The reason i urge you so strongly is that my carpet literly began to burn because of a clogged one and that is scary. Dave.
Posted: Sun Jul 13, 2008 11:26 am
by Aaron88
I checked out the cat. The cat appears to be fine and not clogged. The rattle I'm hearing is a loose heat shield.
Posted: Sun Jul 13, 2008 1:39 pm
by harofreak00
Your car doesn not need a new exhaust system. They are stainless steel from the factory. What you are seeing is surface rust.
Posted: Sun Jul 13, 2008 7:06 pm
by Aaron88
Are the mufflers stainless steel too?
Posted: Mon Jul 14, 2008 12:03 am
by harofreak00
Yes I believe so.
