Im looking for one of those PAC aux inputs for my car, a 2000 SE.
the only reason i ask is i am confused as to which one works. some say 1996-1999 bonnevilles, some say 2002-2006 bonnevilles and the ones that say 2000 in the timeframe say it needs some sort of cd slave unit....?
i want to put one sub in my car just to get some better sound, nothing crazy, so i got the OEM integration box, and evrything for the sub but i wanted the aux because i have a feeling with my fm transmitter my bass will be terrible....
Thanks for the help guys, and info is apreciated :D
btw, im buying all my stuff off sonicelectronix, so idk if they even stock the right PAC
2000 Aux input for sound system....
Liability
- SE Member
- Year and Trim: 2000 Bonneville SE, Bronzemist
Re: 2000 Aux input for sound system....
There is no PAC adapter, it's DIY or nothing. You really have 2 options. Either use an FM Modulator, which wires in line with the antenna, or this method:
viewtopic.php?f=13&t=318&p=1642
Liability
- SE Member
i have seen that tutorial before and was looking for it, so thanks for the link, and i have the same 2000 SE he has, so it WILL work, but i dont have an ipod and i dont really plan on spending a few hundred to get one :/ is there any PAC that uses an AUX cable?
http://www.sonicelectronix.com/item_525 ... X2CAR.html
or even this
http://www.sonicelectronix.com/item_527 ... I-GM9.html
Thanks
and also it says i need a factory specific wiring harness, any idea which one? (first bonneville
or even this
Thanks
