Removal:
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the push pin retainers (2) that secure the rear bumper fascia to the rear wheelhouse extensions.
Remove the fastener (5) securing the rear bumper fascia at the wheelhouse opening.
Disconnect the license lamp electrical connector (2).
Open the rear compartment lid.
Remove the rear compartment sill trim. Refer to Compartment Sill Plate Replacement - Rear in Body Rear End.
Fold back the rear compartment side trim panels. Refer to Compartment Trim Panel Replacement - Rear in Body Rear End.
Remove the fasteners (4) securing the rear bumper fascia (3) to the quarter panels.
Remove the fasteners (1) securing the rear bumper fascia (3) to the rear end panel.
Remove the rear bumper fascia (3) from the vehicle.
Remove the energy absorber from the fascia. Refer to Energy Absorber Replacement - Rear .
Installation:
Install the energy absorber to the fascia. Refer to Energy Absorber Replacement - Rear .
Align the fasteners (1, 4, 5) in the rear bumper fascia (3) to the body.
Connect the license lamp wire connector (2).
Important
The butyl washers on the fasteners (1,4,5) must be replaced upon reassembly. This will ensure that exhaust gases do not enter the passenger compartment.
Install new butyl washers onto the fascia studs.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the fasteners (4, 5) to secure the rear bumper fascia (1) to the quarter panels. Tighten
Tighten the fasteners to 6 N·m (53 lb in).
Install the fasteners (1) to secure the rear bumper fascia to the rear end panel. Tighten
Install the rear compartment side trim panels. Refer to Compartment Trim Panel Replacement - Rear in Body Rear End.
Install the rear compartment sill trim. Refer to Compartment Sill Plate Replacement - Rear in Body Rear End.
Close the rear compartment lid.
Install the push pin retainers (2) to secure the rear bumper fascia to the rear wheelhouse extensions.
Lower the vehicle.
