Total engine power loss when car is heat soaked
Posted: Fri Jul 22, 2011 6:38 pm
'97 SE with the L36
Fuel pump was replaced with a Delco unit about 3 months ago.
When I drive the car for approximately 30 minutes or more it will suddenly lose almost all engine power and start sputtering. After a minute or so of sputtering it will usually die. If I attempt to restart it will sputter for a few seconds then die again. However if I let the car sit and cool down for an hour or so it will start up and run without problems until it gets heatsoaked again. Got stranded in a few less-than-desirable places a couple times until I figured out I had to limit myself to relatively short trips with a good cooldown period in between.
Not sure if it's related, but sometimes I smell fuel when I make a short run and then shut it down, or when I restart it when it's hot.
Fuel pump or evap issues? Something else electrical? I really have no idea on this one.
EDIT: There are no DTCs or misfires when this occurs.
