Inner Tie rod
Posted: Wed Jun 01, 2011 4:48 pm
by 98buicklesabre
Went to get a state inspection finally cleared all my emission codes but failed because of inner tie rod. Any where i can find a write on this for our cars, also any suggestions on brand i should get or does it even matter when comes to this. I usually replace everything with delco but ive spent enough on this car
Re: Inner Tie rod
Posted: Fri Jun 03, 2011 10:20 am
by douellette88
i just went to pepboys and bought their lifetime inner tierod..since mine is bad as well, but i was just planning on bringing it to the stealership to have them change it since you need special tools to change the inner and you "should" get an alignment after
Re: Inner Tie rod
Posted: Fri Jun 03, 2011 12:00 pm
by willwren
The dealership probably won't install a non-OEM part on your car.
Re: Inner Tie rod
Posted: Fri Jun 03, 2011 12:04 pm
willwren wrote:The dealership probably won't install a non-OEM part on your car.
Another reputable shop will, however.
Re: Inner Tie rod
Posted: Fri Jun 03, 2011 12:08 pm
by douellette88
i asked them if it mattered where i bought the part and they said it doenst matter...so hopefully they dont change their mind
Re: Inner Tie rod
Posted: Fri Jun 03, 2011 2:59 pm
by 98buicklesabre
Im going to rent the tool from AutoZone and do the job myself i just bought an ac delco inner tie rod
Re: Inner Tie rod
Posted: Sat Jun 04, 2011 10:07 am
by Archon
