Fuse access
Posted: Sat May 21, 2011 1:59 pm
by 98buicklesabre
I'm trying to change a couple fuses and I understand there are a few locations for them.I can access the bottom instrument panel fuse on the drivers side. Now my question is how would I go about changing the fuses by the sound insulators or the top of the instrument panel fuses. Hope you guys can help thanks
Re: Fuse access
Posted: Sat May 21, 2011 7:06 pm
by imidazol97
98buicklesabre wrote:I'm trying to change a couple fuses and I understand there are a few locations for them.I can access the bottom instrument panel fuse on the drivers side. Now my question is how would I go about changing the fuses by the sound insulators or the top of the instrument panel fuses. Hope you guys can help thanks
There are a few fuses and relays on the A pillar area below the glovebox on the right hand side. Take off the sound insulator under the dash--a few screws. It has a diagram of which relays and fusees are there.
The only other fuses are maxifuses in the Relay Center on the firewall.
Easier to answer: what circuits are you looking to check fuses for?
Re: Fuse access
Posted: Sat May 21, 2011 7:17 pm
by 98buicklesabre
I want to replace my turn signal flasher
