Bleeding cooling system
Posted: Fri May 13, 2011 5:39 pm
How would i go about bleeding a cooling system on a 98 lesabre just want to make sure i have all air out, i see the bleeder just wanna make sure its running good
The forum for Pontiac Bonneville enthusiasts
http://pontiacbonnevilleclub.com/forum/
http://pontiacbonnevilleclub.com/forum/viewtopic.php?t=25742
If the system was drained there may be air in the heater core. The manual says to heat the car until the lower radiator hose is warm (probably after driving it somewhere is best). Run the engine at 2500 rpm for 10-15 seconds. Idle. Repeat for a total of 5 times. I do this with the car in my driveway which has an up hill slope so the heater is lower than usual relative to the rest of the cooling system.98buicklesabre wrote:How would i go about bleeding a cooling system on a 98 lesabre just want to make sure i have all air out, i see the bleeder just wanna make sure its running good
