dandyd wrote:I know it's possible to replace the rod bearings on my '91 olds without removing the engine. Is there a proceedure I should follow and what is entailed with this that I need to be aware of? It appears once the pan is removed the access to the crank is wide open.
It is possible, but not advisable to replace the bearings in this way.
The procedure is simple, drop the oil pan, rotate the crank by hand to bring the rod down to Bottom Dead Center (BDC). Use a feeler gauge to check the side clearance on the rod. It must fall within 0.003" min to 0.015" maximum.
NOTE: You may wish to do all of the rod side clearance measurements first, before you replace any bearings...If one of the rods is out of spec, then you will need to replace the rod or the crank...at which point it has to come out. If the side clearance is Ok on all the rods, then you can replace the bearings. (Too much side clearance will allow the rods to tip & twist..destroying the new bearings. There's no way to correct side clearance issues without replacing or reworking the crank & rods.)
Mark the cap to indicate the direction that faces the front of the motor, then remove the connecting rod cap. Protect the crank journal by slipping rubber hose over the exposed threads of the connecting rod, then use a piece of oak to shove the piston & rod up the bore to get it out of the way. Remove the old bearing halves and note the part number on the back (should have "STD" stamped on it to indicate a standard thickness bearing.)
Clean the crank journal with acetone and a soft cloth.
Take your new standard size rod bearings and install them in the cap & rod. Pull the rod down until it is in contact with the crank journal and remove the rubber hose from the bolts. Lay a stip of Plastigauge on the rod cap bearing and gently install the cap on the rod. Torque the bolts to 43 ft-lbs. DO NOT ROTATE THE CRANKSHAFT...you will smear the Plastigauge and not get a good reading. Loosen the rod bolts, remove the cap, and measure the Plastigauge mashed on the surface of the crank. If it falls between 0.0003" and 0.0026", then it is good to go. If not, you will need an oversize bearing (0.001" or 0.002") to correct the clearance back into the proper range.
Clean the crank journal with acetone and a soft cloth. Clean the rod cap bearing with acetone and a soft cloth. Lubricate the bearing with engine assembly lube and reinstall. Torque to 43 ft-lbs.
Take a break...One down, five more to go.
Now, At the begining I said this was possible, but not recommended. Here's why: You are installing brand new bearings on a worn crankshaft. Not exactly a good idea. The correct method is to remove the crank from the engine, then turn/grind/polish all the journals to the next size down. That removes all wear, taper, and damage from the crank so the new bearings have a perfect surface to ride on.
