Noise when turning right
Posted: Wed Mar 30, 2011 9:09 am
by Jake
99 SE
253k
Have a noise when turning right, only when turning right, happens at all speed, i think i can pinpoint it to the top of the strut? i put some white lithium grease on there but it doesnt seem to help, do i need to replace this strut? any input would be appreciated , thanks, jake
Re: Noise when turning right
Posted: Wed Mar 30, 2011 9:10 am
by harofreak00
Try pouring a little motor oil instead of the white lithium grease.
Posted: Wed Mar 30, 2011 11:14 am
by washboy2
check your cv joints and grease all the zircks on both sides
Posted: Wed Mar 30, 2011 6:11 pm
by Jake
thanks guys, will try these methods
Posted: Thu Mar 31, 2011 8:22 am
by willwren
CV joints will be a long shot at best. Concentrate on the stut and the hub/bearing assembly for now, get on the car and shake things. Jack up that side and wobble the tire around.
Posted: Thu Mar 31, 2011 4:35 pm
by Jake
thanks for the input guys, the motor oil trick worked, no more noise! :)
Posted: Thu Mar 31, 2011 7:12 pm
by harofreak00
The motor oil trick will only work for so long. You'll have to keep adding more. Eventually the oil will cause the rubber to deteriorate and you will have to replace the strut mounts. The trick is just to hold you over for a while. Good luck.
