95 L67 Performance
Posted: Sun Feb 20, 2011 10:57 pm
Hey guys I am pulling exhaust manifolds for crack checks and I have the front one off and do not see anything obvious (haven't pulled heat shields yet), where do they crack? At the welds or under the heat shields?
Also should I add Felpro gaskets when I put them back on? There were no gaskets when I took them off.
Also are the series 2 coils the ones with grey dots on the bottom? Do they need to be factory or do aftermarket oe replacements have the same output? I am looking to upgrade to the 97+ coils.
I am working on the fuel system too. About a year ago I installed a new Delphi fuel pump and high flow filter from ZZP. The fuel pressure readings were exactly the same before and after new pump: prime (koeo) 45psi+ and 35psi @ idle. I have had no driveability issues other than the slight feel of missing power except for the occasional xtra Zing one day and gone the next, by zing I mean waay better throttle response, like LESS throttle & ALOT more GO. Every once in awhile it will have a good day like that. Fuel is Always 93 octane from Mobil/Exxon and SeaFoam in the tank every so often (did the hot soak after fuel pump). Sooo, I sent my injectors off to Cruzin Performance for flow test and ultrasonic cleaning (I'll add a link to the data later), and I also got a new pressure regulator and a NTK O2 sensor. Am I on the right path here to get to the 41psi+ fuel pressure that I am lacking? I have owned the car for almost 4 years and have put 55,000 on it and it has only set a code once when i started it @ -20F one morning back in IL, no codes set other than that.
Injector Results
Thanks!
Injector Results
Thanks!
