FWI install for 2000+
Posted: Wed May 21, 2008 8:17 pm
by Gumball
1 .Remove the stock air box and bellow -3 screws
remove PCM from air box - just slips out-sorry no pic
2 .remove IAT sensor from bellow
3 .jack up car and remove LF tire
4 .remove about 7 push tabs from inner fender well liner- carefully
5 . bend up out of way the fender liner.... hey look theres the horns.
6 .after cleaning area where air box was
Install PCM tray from Intense with 3 screws provided (i only used 2)
7 .snap PCM into tray
.Now on to the filter
8 . connect K&N filter to fender well hose
by the way the hose looks ruff/bumpy on the outside but is smooth on the inside.
9 .slide hose up the inside fender well and out through the hole
10. connect rubber coupler to the throttle body and connect IAT sensor the the coupling
11. connect hose to the coupling
connect IAT wire
I may cut it down as i think its a tad to long. but we'll see
replace inner fender well lining
replace tire
start car and you can hear the air going through the tubing.
Take for a test drive
Re: FWI install for 2000+
Posted: Fri May 23, 2008 6:17 am
by MaxNismo
hot jim.
nice write up.
want to race
Posted: Fri May 23, 2008 6:15 pm
by Alibi
Ahh... so the filter does just sit in the well. I've been wondering about this for a long time as to whether this is feasable on an 87-91 car. Looks like I'd have to stuff the filter in the EVAP canister hole or something.
Know of anyone who has tried this on an 87-91 for sure though?
Posted: Fri May 23, 2008 6:33 pm
by Jrs3800
Alibi wrote:Ahh... so the filter does just sit in the well. I've been wondering about this for a long time as to whether this is feasable on an 87-91 car. Looks like I'd have to stuff the filter in the EVAP canister hole or something.
The set up would be the same as my 95, but I think the LN3 throttle body is a bit smaller..
But I will still say I love my intense Intake
Posted: Sat May 24, 2008 1:34 am
by laxmangl
How many feet of tubing from intense did you need
Looks great by the way. That will be my first performance mod when I get the money
Posted: Sat May 24, 2008 2:48 am
by TenGHz
Do you really have to remove the tire to do this? I thought you could just remove the headlight to get at all the necessary areas...?
Posted: Sat May 24, 2008 2:58 am
by viper8907
I think the only way to get the filter down in the fender is through the wheel well. I dont think it will fit down behind the headlight. My guess is that taking the wheel off is the only and/or easiest way, if there were a better way, Intense would probably use that in their directions.
Posted: Sat Aug 15, 2009 2:27 pm
by jdronzek
This was a great write up. Especially for a engine newbie like me.
Posted: Sat Aug 15, 2009 3:59 pm
by gonzo4191
i installed mine through the headlight opening
Posted: Sat Aug 15, 2009 4:21 pm
by 01bonneSC
You can get it in behind the headlight with a lot of squishing/bending of the filter, not recommended
Posted: Sat Aug 15, 2009 5:30 pm
by Gumball
old school bump allowed for newbies of the club
after looking at those pics again, boy am I glad I don't have those old rusty rotors still.
and thanks for the comps on the write up. but if you were to purchase intense FWI system it comes with clear instructions
Posted: Mon Aug 17, 2009 12:20 am
by 01bonneSC
Shouldnt this just go in TechInfo?
Posted: Wed Aug 19, 2009 12:00 am
by kristie_jeff
I would soo love to do this, but I like to give my engine bay a wash every now and then, and I have a feeling that would have to stop with the PCM out in the open like that.
Excellent write up though. Thanks
Posted: Wed Aug 19, 2009 1:10 am
by harofreak00
The PCM connections are completely waterproof. No worries.
Posted: Sun Aug 30, 2009 1:22 pm
by Mac077
Just got through with my FWI install and this was exactly what I needed to make it a breeze. I will be posting pics in a little while showing the horizontal install just behind the headlight assembly as aposed to the vertical install down into the fenderwell. All I had to do was take the headlight out and I didn't even have to disconnect the headlight either. Pretty easy and thanks Gonzo for the assembly!!
Posted: Mon Aug 31, 2009 5:45 pm
by gonzo4191
no problem
Posted: Mon Sep 07, 2009 1:03 pm
by Mac077
Ok, sorry for the long delay but here are a couple of pics with it installed...
...as you can see I didn't even have to completely remove the headlight and I have the PCM zipped tied for now until I can get it screwed in somewhere that looks appropriate.
Cose up of filter tucked in behind the headlight. It fit very easily and did not have to be bent at all! It looks like it was because I didn't use my brain before I used my brawn!
Over all it was a very simple process...I hope you like it...I call it my "Gonzo"!! And yes, I know I need to clear my headlights!! Had them cleared before the accident but haven't gotten to the new ones yet!!
Posted: Mon Sep 07, 2009 8:34 pm
by excessive81
i just did this on mine as well during the blower install. i ordered 3 ft but used about 2.5. and i didn't pull the wheel/wheel well i pulled the lower air dam off as i wanted my filter as close to the bumper opening as possible.
Posted: Tue Oct 26, 2010 4:03 pm
by AJT2004
i was looking for a write up on the FWI for my 2004 se
. this is perfect thanks. how is it replacing the filter tho, and how do i remove the pressure pins that hold in the fender lining.
Posted: Tue Oct 26, 2010 7:04 pm
by 01bonneSC
I don think this is in TechInfo. Should be, or atleast a sticky for 00+ or in Performance and Brainstorming. Would stop a lot of people asking the same questions, especially recently.
