Dash
robjr69
Year and Trim: 1996 Pontiac Bonneville SE
Dash
Post by robjr69 »
I need some help and advice. The P R N D L 1 2 lights on the dash light up red and then whatever gear you are in it turns yellow. well the N is lite up red and when I put the gear in N the light goes out instead of turning yellow. Does this mean it needs a new bulb in there? or is something else wrong. Thanks for all your help.
2000GreySSEi
Re: Dash
Post by 2000GreySSEi »
Sounds like its most likely a bulb. But not 100% sure, maybe others with more experience with that will help you.
2000 SSEi 4th Pontiac!! 231,xxx Current mods: Gutted AirBox w/ K&N drop in. Cleared Corners. Future mods: 3.5 pulley, 180* tstat, hi flow cat, solid motor mounts, Red-Tinted Turn Signal Tails, Projector Headlights, Turn Signal Mirrors.
Re: Dash
Ya, the orange LED is burnt out.... never heard of that happening before. I should be able to repair it though.
yourgrandma
Year and Trim: '02 SSEi
Re: Dash
Post by yourgrandma »
My P does that. It flickers sometimes leading me to believe its a loose contact somewhere or a bad solder connection at the board.
