ABS & Traction stays on
Posted: Sun Oct 03, 2010 1:19 pm
by Kevin Amstutz
My 98 has the ABS and Traction control light that stays on. During intial key on, the ABS & traction light will not flash, steady on. Both of my wheel sensors are at 1050 & 1100 ohms, which are in spec. Max fuse on firewall and interior fuse panel is good. Any other ideas?
Re: ABS & Traction stays on
Posted: Sun Oct 03, 2010 1:24 pm
Check the resistance of the wiring to them. Being in WI, you could have a wire that's corroded through.
Posted: Sun Oct 03, 2010 1:44 pm
by Kevin Amstutz
The wheel end connectors back to the computer?
Posted: Sun Oct 03, 2010 2:10 pm
by Kevin Amstutz
The manual says to rotate the wheel and check the wheel bearing connector end for 100mv. I put the car in gear to spin the wheels and with my Fluke meter set at the 300mv selection, both sides read 0 mv. I can't see any problems with the wires or connections. Anymore ideas?
