1998 auto A/C
Posted: Sun Sep 26, 2010 5:26 pm
by Kevin Amstutz
My 1998 auto A/C will not power the compressor clutch. I have no blinking codes on the display and I swapped relays. At the A/C clutch relay, I have power at pin 30 & 86 which is fused power supply. I can get the clutch to engage when I jump pin 30 to pin 87. When will pin 85 get power to or from the PCM? It appears the PCM gets a signal from the pressure switch. Is there anyone that could help trouble shoot or explain the system in more detail?
Re: 1998 auto A/C
Posted: Sun Sep 26, 2010 7:40 pm
by TheEngineer
Is there sufficient pressure in the system?
Re: 1998 auto A/C
Posted: Sun Sep 26, 2010 7:59 pm
by gmman
you may have the AC compressor that has a pressure transducer. i don't have access to a 98 FSM. i am posting how my 96 with ECC is configured. pins might not be the same. basically the transducer screws into the compressor and generates a voltage from 0 to 5 volts (5 volts is supplied by the PCM). the pressure transducer will supply a portion of that 5 volts depending on freon pressure in the system. my tests indicate about 2 to 4.5 volts for normal pressure. anything outside that and the PCM will disable AC clutch control relay. from your description of the problem, the AC clutch relay is not being energized so it appears the PCM is not supplying a ground to pin 86.
my problem was not freon pressure out of tolerance but the pressure transducer itself had failed. NAPA had replacement.
PS you will not lose freon when you unscrew pressure transducer. there is a shrader valve underneath pressure transducer. if you look down on the compressor from the radiator you will see the pressure transducer in the high pressure line. will have three wire connector.
so, this is just a guess as to how your model year energizes the AC clutch and you could still have freon pressure problems.
Re: 1998 auto A/C
Posted: Sun Sep 26, 2010 8:34 pm
by Kevin Amstutz
Really nice diagram! My 98 FSM is pretty much the same. I have pressure in the system and I have 4.2V grey wire at the pressure transducer. I'm also thinking that the pressure transducer is bad. I will swap it out with my other Bonny tomorrow and see what happens. Thanks!
Re: 1998 auto A/C
Posted: Mon Sep 27, 2010 8:17 pm
by Kevin Amstutz
Fixed! It was a bad pressure transducer. Thanks for all the help!
