IAfter viewing the posting here [ http://www.pontiacbonnevilleclub.com/fo ... ew&p=39609 ] concerning the blend door not opperating properly.
I located my blend door actuator and removed it and it is not broken. I can apply 12 volts directly to the motor and it functions ( spins the motor and transmission, reverse the wires and it reverses the motor. ) . I don't know if the potmeter is bad or if the sending unit on the dash board is bad. Is there a way to either test the line that plugs into the actuator for the correct signal or a way to test the actuator? ( besides using specialized or propriatary testing equipment) This is on a 2000 Buick Century, I know it is not a Pontiac but it is still a GM product and the procedure should be the same. I thank you for any advice you can offer ( I know I can go and buy an actuator then plug it in to see if that solves the problem but money is tight and I don't want to buy anything till I narrow it down more )
blend door problem on 2000 Buick Century
billschillin
- LE Member
- Year and Trim: 2000 Buick Century
Return to “Your Other Rides: Pics and Videos”
Jump to
- Announcements
- ↳ NOTICE
- ↳ Introductions for new members
- General
- ↳ General Chat
- ↳ Your Ride: Pics and Videos
- ↳ Your Other Rides: Pics and Videos
- ↳ On the Road and at the Track
- ↳ Performance & Brainstorming
- ↳ Audio (and aftermarket electronics)
- ↳ Detailing & Appearance
- ↳ Vendor's Forum
- Mechanical and Maintenance (no chat or performance)
- ↳ Techinfo
- ↳ Techinfo DB
- ↳ Specifications and General Information
- ↳ Electrical
- ↳ Powertrain (Ignition, sensors, etc)
- ↳ Accessories
- ↳ Lights
- ↳ Computer (PCM)
- ↳ Other - Electrical
- ↳ Mechanical
- ↳ Engine
- ↳ Transmission/axles/hubs (things that spin)
- ↳ Suspension & Steering
- ↳ Superchargers
- ↳ Other - Mechanical
- ↳ Exterior
- ↳ Interior
- ↳ Performance
- ↳ Care and Feeding
- ↳ Bonneville GXP/Northstar Powered Cars
- ↳ 2000-2005 (other than GXP)
- ↳ 1992-1999
- ↳ 1987-1991
- ↳ Classics (Star Chief and 1957 to 1986)
- ↳ Everything Electrical and Electronic
- ↳ Forced Induction
- ↳ Other 3800 powered cars
- Gatherings
- ↳ National/Regional/Local Meets
- The Site
- ↳ Suggestions
- ↳ Test
