Fog Light HI beam over ride
Posted: Sun Aug 08, 2010 2:35 pm
by bobtaz13
I was asked how I did my HI beam over ride for my fog lights.
Wire color and locations change so this is the base that i used for both my cars.
Re: Fog Light HI beam over ride
Posted: Sun Aug 08, 2010 3:01 pm
by SAMzGXP
interested, still dont get it though
by Rusgreim
At least in Indiana, this would be illegal, so anyone considering this should check their local laws.
Posted: Sun Aug 08, 2010 4:00 pm
by bonneville dan-o
Rusgreim wrote:At least in Indiana, this would be illegal, so anyone considering this should check their local laws.
will they seriously pull you over for having foglights on with your high beams?
thats ridiculous.
Posted: Sun Aug 08, 2010 4:10 pm
by bonnevillain
There is a limit to the number of lights that can be lit on the front of your vehicle, which I believe is 4. Since the 2000+ Bonnevilles have the low beams and high beams on at the same time, add the fog lights to that and it makes 6 lights.
But I highly doubt the cops around here would pull you over.
Posted: Sun Aug 08, 2010 4:20 pm
by Rusgreim
A good friend of mine who was not in anyway a hot dogger of showoff was pulled over AND ticketed because he had aftermarket fog lamps that were on at the same time as his other 4 lamps. Sometimes, cops get bored.
Posted: Sun Aug 08, 2010 6:33 pm
by John Deere Boy
SAMzGXP wrote:interested, still dont get it though
Without the high beams on, the foglights operate as normal, but when the high beams energize the relay, the fogs get power directly from the battery.
Posted: Mon Aug 09, 2010 10:02 am
by anwisdom
bonneville dan-o wrote:Rusgreim wrote:At least in Indiana, this would be illegal, so anyone considering this should check their local laws.
thats ridiculous.
YES!! I was pulled over for having my fogs on within city limits. It was only a local law (Stillwater, OK) but some cops will pull you over for "illegal lighting."
Posted: Wed Aug 11, 2010 9:50 am
by CMNTMXR57
It's not the number of lights you have on, it's the amount of candlepower that is possible by having your low beams/fogs on with the high beams. It's just standard thought that if you have your high beams on, any low beam of fog light would put you over the threshold
With that said, I've done this on many vehicles and never had issue with any law enforcement (keep in mind, I'm in a metro area of 9 - 10 million people, so there are a lot of police around too). Reason being, I'm not using the high beams (with fogs and low beams on) when I'm in traffic.
I've never attempted it though on my Bonneville, so I can't answer any how tos on this.
Posted: Wed Aug 11, 2010 5:34 pm
by bobtaz13
The way i look at it is if the cops can see your hi's and fog light on at the same time, then your to close to him with your hi's on. In MN your not alowed to have more then 4 lights on eather hi or low, as i remember it atleast.
Posted: Fri Aug 13, 2010 4:35 pm
by nunesjeff
I have converted my bonneville to run all 6 lights and have not been hassled about them at all... viewtopic.php?f=21&t=16130
