rough idle
Posted: Tue Jun 15, 2010 11:38 am
by adams11
I have a 1996 bonneville se with a 3.8. I have already taken out the MAF and cleaned it but that still hasnt worked. Also just replaced with a new alternator. Slight belt squeekage but after a while the rough idle will quit and runs fine.
Re: rough idle
Posted: Tue Jun 15, 2010 12:08 pm
by J Wikoff
When was the last time it had new plugs and wires? It smoothing out after a bit might be a clue to something, but I can't remember exactly what.
Re: rough idle
Posted: Tue Jun 15, 2010 1:52 pm
by Dopey85
I'd say plugs, wires, and possibly check for a bad coil.
Re: rough idle
Posted: Wed Jun 16, 2010 11:30 am
by adams11
i just changed the plugs and plug wires probably about 2 months ago
Re: rough idle
Posted: Wed Jun 16, 2010 12:37 pm
Have you checked and cleaned the IAC motor and its bore in the TB? It's the round plastic thing on the top of the TB that goes in sideways.
Re: rough idle
Posted: Wed Jun 16, 2010 3:59 pm
by adams11
i just got the code number its p0102 MAF or VAF circuit low imput
Re: rough idle
Posted: Wed Jun 16, 2010 6:40 pm
by Dopey85
double check and make sure the connectors is fully seated. If that doesn't work inspect the wires, connectors, and pins real good and make sure there aren't any cracks, corrosion, or chaffing. And if that doesn't fix the problem get a multimeter and/or test light check if there is or how much output is coming out of the connectors.
Re: rough idle
Posted: Wed Jun 16, 2010 10:03 pm
by J Wikoff
Take out the MAF, and carefully clean the elements with rubbing alchohol on a q-tip.
Re: rough idle
Posted: Thu Jun 17, 2010 12:26 am
Does the rough idle stop when the MAF is unplugged?
Re: rough idle
Posted: Thu Jun 17, 2010 9:30 am
by adams11
I've taken out the MAF and used some MAF cleaner on it. It was pretty dirty. And i have not yet tried to unplug it to see how it runs without it
Re: rough idle
Posted: Thu Jun 17, 2010 10:42 am
When it's doing its rough idle, unplug the MAF sensor and see how it changes.
