1992 Bonneville knock sensor
Posted: Mon May 17, 2010 2:08 am
by Merrillspontiac
my buddy has a 92 Bonne SE and from time to time the SES lite comes on ad when I did the paper clip trick code 43 came up. How hard is it to change the knock sensor?
Re: 1992 Bonneville knock sensor
Posted: Mon May 17, 2010 2:27 am
by myfirstbonnie
Just pulled my FSM: Have you checked the circuit? You should have 4-6 volts on the lead when the ignition is on and sensor is disconnected. It is located on the back side (firewall) of the block.
Posted: Mon May 17, 2010 9:14 am
by J Wikoff
It's on the passenger side of the back. You'll need a cresent wrench, I forget what size. If you crawl under, and look up, it'll be 1.5-2" in diameter, and have a one wire lead.
Posted: Mon May 17, 2010 11:26 am
by Merrillspontiac
Do I have to reach up between the engine and trans to get at it?
Posted: Mon May 17, 2010 12:13 pm
by J Wikoff
You'll reach between the trans and firewall, and be working above the trans.
Posted: Mon May 17, 2010 3:25 pm
by Merrillspontiac
would that cause extended cranking when cold and intermitent rough idle?
Posted: Mon May 17, 2010 3:33 pm
by J Wikoff
Not likely.
I can look in my FSM for code 43 diagnosis when I get home from work. I'll let you know if there's any other directions to go here...
Posted: Mon May 17, 2010 3:38 pm
by Merrillspontiac
Thanks, That be great.
Posted: Mon May 17, 2010 8:37 pm
by J Wikoff
First, check if the harness is close to any ignition wires. If it is, move it away.
Then:
Disconnect knock sensor, Ignition ON not running, the voltage between the harness connector and ground should be 4-6 volts. If not, check the harness for shorts/bare wire.
The resistance between the knock sensor connector and the block should be between 3.3k and 4.5k ohms. If it's not, replace the sensor. Do not apply anything to the threads, install it dry.
If both test out ok, and the code comes back after you make sure the connector is properly seated, there are some other things to look for. The harness getting false voltage from a nearby wire, the eprom isn't seated properly, or the eprom is bad.
Posted: Mon May 17, 2010 10:30 pm
by Wes
21mm wrench. I think a 22 will work too.
