4T60 E Fluid capacity??
Posted: Tue Feb 23, 2010 7:56 pm
by 2000Silverbullet
Need a quick answer for a pan drop and filter change for the 94 SSEi.
Re: 4T60 E Fluid capacity??
Posted: Tue Feb 23, 2010 8:10 pm
by Jrs3800
Generally in the area of 6 to 7 quarts... Depends on how much you get out really.. I have used 5.75 to 6 easily, but I always buy 7..
Posted: Tue Feb 23, 2010 9:32 pm
by bill buttermore
Yep, about 6 or 7 quarts is what we said in the Techinfo Article
Drop & Clean Trans Pan
Posted: Tue Feb 23, 2010 10:46 pm
by londonontman
Speaking in Canuckeese I just did my tranny and the fluid capacity book we use says the capacity was 5.7 litres but it took more like 7 litres. That being said if you look at the dipstick when checking the level (in park, engine warm) you will see the cross hatching on the dip stick. Fill to the top line then add one more litre. This may sound excessive but in talking to a master technician he says that the markings on dipsticks are generally at the minimum requirements the tranny needs. Adding one extra litre will not hurt and will actually make the tranny run smoother. GM's are notorious for this
Posted: Tue Feb 23, 2010 10:52 pm
I've heard add a pint, but not a full liter. Too much can cause foaming and other damage, especially in non- FWD transmissions.
Posted: Tue Feb 23, 2010 11:27 pm
by LeSabre in Buffalo
I'm running half a quart over full right now. No issues. I also ran a quart over full for ~30k miles with zero issues.
Posted: Wed Feb 24, 2010 12:00 am
by LeSabreUltra
Hmm, I may try this...I have always kept it in between the two dots...
Posted: Wed Feb 24, 2010 1:20 am
by 2000Silverbullet
Great, I'll buy 7 liters of Dex 6. It's almost $7 a liter!
I don't like the puddling that the Grizz is leaving in this nice underground heated garage.
I know the level is low and from the colour on the dipstick needs to be done this weekend.
Thanks guys.
Posted: Wed Feb 24, 2010 8:46 am
by londonontman
1 litre extra is not going to harm the tranny. There is no foam issue. I am only speaking of the 4t60-E transmissions here. And Silverbullet....Why are you going to add Dex 6 to your transmission when its not necessary. I have only seen it needed in post 2006 GM cars and trucks. ATF3 will work just as well in your 2000.
Posted: Wed Feb 24, 2010 8:50 am
by Jrs3800
Its for the 94... and the Dex 6 has a better additive package no matter how you slice it up... I use it in all of my transmissions these days...
Posted: Wed Feb 24, 2010 9:33 am
Like Don said, the Dex-VI has a much better additive package. It also has much better base oils than Dex-III. The upside is much better protection and flow when it's cold, and better protection when it's hot. Plus it's compatible with all previous Dexron specs.
Posted: Wed Feb 24, 2010 10:02 pm
by londonontman
I never received any tech info at work about Dex6. I know that we have it in a 5litre Mobil1 container. I just assumed it was overkill in a tranny that was taking ATF3
Posted: Wed Feb 24, 2010 10:18 pm
by GoldenBullet
Would the fact that not all of the Dex III is drained out when doing a pan drop be a concern when you replace it with Dex-VI? Or are they compatible enough to intermingle?
Posted: Wed Feb 24, 2010 10:19 pm
They're compatible, AFAIK.
Posted: Thu Feb 25, 2010 12:08 am
by 2000Silverbullet
Perfectly compatible.
They only had three litres in stock so I had to go back after work to pick up all 7 with the filter. $75. with tax.
It would cost a lot more if I brought it into a shop to have done with regular Dex.
Darn, it's going to rain all weekend. I hate working in the rain.
