Engine Specs 3800/ Northstar / Shortstar and others
The numbers.....
Moderator: Gearheads
Post by Jrs3800 »
The 3.8 and 3800 has seen many changes over the years... And have been attached to several transmissions...
HP and Torque Ratings
The 87-88 Vin 3, 3.8V6 HO made 150 Hp @ 4400 Rpms and 210 Ft Lbs @ 2400 Rpms Rpo LG3
The 88-91 Vin C 3800 MFI made 165 Hp @ 4400 Rpms and 220 Ft lbs @ 2800 Rpms Rpo LN3
The 92-94 Vin L 3800 TPI made 170 Hp @ 4800 Rpms and 225 Ft Lbs @ 3200 Rpms Rpo L27
The 92-93 Vin 1 3800 SC made 205 HP @ 4600 Rpms and 260 Ft Lbs @ 2600 Rpms Rpo L67
The 94-95 Vin 1 3800 SC made 225 HP @ 5000 Rpms and 275 Ft Lbs @ 3200 Rpms Rpo L67
The 95-05 Vin K 3800 II made 205 HP @ 5200 Rpms and 230 Ft Lbs @ 4000 Rpms Rpo L36
The 96-03 Vin 1 3800 II made 240 Hp @ 5200 Rpms and 280 Ft Lbs @ 3600 Rpms Rpo L67
Other Engines of topic on this forum...
99-02 Vin H - 3.5 Twin Cam( Shortstar ) 215 HP @ 5600 Rpms and 230 Ft Lbs @ 4400 Rpms RPO LX5
93-95.5 Vin - 3.4( OHV, Camaro-Firebird ) 160 HP @ 4600 Rpms and 200 Ft Lbs at 3600 Rpms Rpo L32
94-99 Vin M 3100 V6( 3rd Gen 3.1 )155-160 Hp @ 5200 and 185 Ft Lbs @ 4000 Rpms Rpo L82
91-00 Vin - 2.2L4( Pushrod OHV ) 120 hp @ 5200 and 130 Ft Lbs @ 4000 Rpms Rpo LN2
86-96 Vin - 2.3L4( Quad 4 DOHC ) 150 HP @ 6000 Rpms and 145 Ft Lbs @ 4800 Rpms Rpo LD2
95-02 Vin - 4.0 V8( Northstar ) 250 Hp @ 5600 Rpms and 260 Ft Lbs @ 4000 Rpms Rpo L47
94-96 Vin - 4.3 V8( 265 ci in B body ) 200 Hp @ 5200 Rpms and 235 Ft Lbs @ 2400 Rpms Rpo L99
91-96 Vin - 4.9 V8( 299ci, K body ) 200 Hp @ 4100 Rpms and 275 Ft Lbs @ 3000 Rpms Rpo L26
