Infrequent fuel leak
Posted: Fri Jan 08, 2010 8:58 pm
by azu
It is leaking at the quick connect feeding the fuel rail (In coming fuel). Only leaks maybe once every week or two but enough for concern. My question is:
Are the clips a one time use or are they a part of the hose and must be replaced as a whole unit?
Re: Infrequent fuel leak
Posted: Fri Jan 08, 2010 9:19 pm
by Mechanical Mike
The clips are reuseable. I think there's an O ring in the hose that can be replaced. I'll go check the FSM.
Posted: Fri Jan 08, 2010 10:57 pm
by bonnie02rkt
Hey I had that same issue about a month ago; yea there is a small o-ring in there and mine was smashed up pretty bad causing a pool of gas on the manifold. I freaked when I saw it; I was not lookin for any engine fire to break out!
Posted: Fri Jan 08, 2010 11:25 pm
by 1fatcat
There are actually two o-rings in there.
Posted: Sat Jan 09, 2010 12:59 am
by Mechanical Mike
Where did you get the O rings?
Posted: Sat Jan 09, 2010 2:13 am
by azu
Mechanical Mike wrote:Where did you get the O rings?
I want to know also. I could get some from a JY.
Posted: Sat Jan 09, 2010 10:33 am
by 1fatcat
The only place I know of is to buy a replacement end for the fuel line (I know Oreilly's sells them, maybe Napa too?) and you can either replace the whole end section or rob the o-rings from the new end and just replace the o-rings. Replacing the end section usually involves warming a plastic fuel line and forcing it over a barbed fitting and it can get tricky.
