Brake dragging/ hanging up
Posted: Tue Sep 22, 2009 8:56 pm
So I've noticed that my front driver side rim have been getting rather dusted by brake dust. Which is odd since I switched to full ceramic pads. Then with closer inspection the rotor is extremely hot compared to the rest. To where the rim is considerably warmer then the rest of them.
First I bled the line to check for air. Line was good.
Still hangs up.
Tried turning traction control off. Maybe thinking it was like the wheel speed sensor malfunctioning and the black was grabbing slighting to "slow" the tire down (this may have made no sense to some one that knows what they're doing)
Still hangs up
today I pulled the caliper off exercised the pistons, cleaned the pad knobs where they go into the slides, cleaned the slides. Everything seems to be moving smoothly.
(we'll see how it works on the drive to work in the morning)
Any other suggestions. Happen to any one else?
brake fluid level is good.
pads are warn evenly rotor looks fine. no extensive wear.
It's just hanging up enough to heat the rotor to a untouchable state.
it hasn't warped and there are no hot spots.
Car isn't pulling while driving or braking.
Gas mileage is suffering (not noticeably)
Still hangs up.
Still hangs up
