01 SE with manual controls. the hvac blower will not work. i bought another motor from the yard and plugged in. no luck.
i double checked the 3 connectors i could see connected to the motor area and they looked good. the lights on the dash controls light up. not sure where to check next or what to troubleshoot.
anybody offer some insight??
HVAC blower doesn't work
imidazol97
- Posts like an L67
Re: HVAC blower doesn't work
From my 2003 leSabre Helms service manual:mlkmgr wrote:01 SE with manual controls. the hvac blower will not work. i bought another motor from the yard and plugged in. no luck.
Fuse block rear seat #2 30A
Power to blower
Fuse block rear #37 10 A
to the control unit on
Have you check for power at the three prong connector to the blower?
A is a feedback wire
B should have 12 V when blower is on
C should be ground
I'd check these connecting to a good ground with your meter.
I suspect you'll find your problem in these checks.
The blower motor i run through a blower Motor Control Processor box. The ground wire goes to that box and the box shows a ground.
- Year and Trim: .
I am looking at a 2000 FSM and on the 3 prong connector to the blower motor:
pin A black wire speed control
pin B purple wire battery voltage
pin c brown wire blower motor flange ground
There is a blower control module mounted on the side of the AC housing that gets inputs from the HVAC controls for the blower. When the blower commanded on, check the voltage between pins A and B. It should vary between 4 to 6 volts when the fan speed commanded is changed.
thanks for the replies. the car is in on a road trip at the moment. will check the voltages when the car returns.
i forgot all about the fuse block under the rear seat. perhaps it is something as simple as the fuse....i hope!!
- Year and Trim: .
Yes, I was assuming that was verified, but if the original motor went bad it probably took out the fuse.
