Page 1 of 2
Differences in speedo's
Posted: Sun Jun 01, 2008 1:58 am
by fastblackbeauty
My HUD display for my 94 SSEi gives me two different speeds...at 35 on the dash, I show around 38 on the HUD, and it climbs from there. My question is, which friggen one do I believe? At 70, the difference is almost 8 MPH, definately enough to get a ticket with. Any information would be greatly appreciated.
Re: Differences in speedo's
Posted: Sun Jun 01, 2008 2:03 am
by L67Silhouette
My Cutlasses with HUD did that too...Very weird.
Posted: Sun Jun 01, 2008 2:12 am
by Peterg22000
I read an artical once reveiwing the SSEi, it said that there was a differeance in the HUD to the speedo, it said there testing showed the HUD to be the correct one...
however this doesn't mean thats the case for your car..
Posted: Sun Jun 01, 2008 2:14 am
by bonnevillain
do you have a GPS devide to compare to? or one of those permanent speed signs?
Posted: Sun Jun 01, 2008 2:18 am
by GonneVille
The HUD is less likely to be wrong. It reads the signal and displays it electronically, very few things that can be thrown off there. The speedo, OTOH, has mechanical elements than can be thrown off after years of bouncing over rough roads, or could even be assembled wrong in the first place.
Go with the HUD reading.
If you really feel paranoid, find a radar trailer and buzz it. (Make sure it's not a ticket camera, first, obviously...) Go with whichever is closer to the trailer's display.
Posted: Sun Jun 01, 2008 11:07 am
by willwren
The HUD can't be more than 1-2mph off at 65mph by the way it works. That signal is coming from the reluctor wheel which is part of the differential. It counts pulses per mile and displays them in their pure form.
The speedo is electro-mechanical. It has loss, as well as drag.
jstpsntym on the old forum had a very good procedure for calibrating the two that he shared with amy_lynn:
1. Speed up the car until you reach a speed that shows the HUD faster than the speedo.
2. Roll down your window.
3. Reach around in front of the windshield (you need long arms for this or some help through the sunroof), and grab the green numbers floating in front of the car.
4. Hold onto the numbers until the speedo catches up with the HUD, then let go of the HUD numbers.
This works better when it's not raining. The hud numbers get really slippery and hard to hold onto when they're wet (my own little personal observation).
Seriously, the HUD is correct, the speedo typically lags behind, especially during quick accelleration.
Posted: Sun Jun 01, 2008 11:24 am
by JMH1950
Posted: Sun Jun 01, 2008 4:23 pm
by TenGHz
Could I add a HUD to my non-HUD'd car by following the above procedure? I could just borrow someone's car that has one, and steal it.
Posted: Sun Jun 01, 2008 5:44 pm
TenGHz wrote:Could I add a HUD to my non-HUD'd car by following the above procedure? I could just borrow someone's car that has one, and steal it.
ROTFLMAO
Posted: Sun Jun 01, 2008 7:17 pm
by BonneMe
The Hud will be electronically correct given the sensors and wiring is fine. But unless you have the exact height tires that the factory equipped, it may be off.
Posted: Sun Jun 01, 2008 9:17 pm
by mawint
i would go with whatever one is higher then the other, then you know your either doing the right speed limit or below it
Posted: Mon Jun 02, 2008 10:14 am
by Billha
I think I recall reading a TSB about the difference between the HUD and the speedo.
Posted: Mon Jun 02, 2008 10:22 am
mine are pretty close, but i can tell the HUD is faster to respond, due to facts stated above. I would trust the HUD, esp if it is higher, b/c then you are doing the speed limit or under, as stated above
Posted: Thu Jun 05, 2008 12:36 am
by fastblackbeauty
willwren wrote:The HUD can't be more than 1-2mph off at 65mph by the way it works. That signal is coming from the reluctor wheel which is part of the differential. It counts pulses per mile and displays them in their pure form.
*dang*, those are slippery little buggers!!! Will have to try again another time when sleet is not hitting me in the face.
Tried again, this time I got them. Only ran over one nun, two dogs and three cats, and I think a VW bug, but I have a problem, so now what do I do when the little green numbers come off in my hand, Bill?
Seriously though, thank you all for the help. I was always going with the HUD because it does read faster, just to be safe, but I thought I would find out from the *ahem* experts.
to you!
Posted: Thu Jun 05, 2008 11:44 am
by pearl_bonnie02
Posted: Thu Jun 05, 2008 1:20 pm
by Echo SSEI
Of course, if you want to sort-of "test" how accurate either is, you could find a stretch of roadway, set the cruise control to 60 MPH (according to the HUD or the speedo), and then using a stopwatch or other timing device, see how long it takes you to get from one mile marker to the next. In theory, if the mile markes are accurately placed, at exactly 60 MPH, it should take you 60 seconds between mile markers. Even if they are not totally accurate, it is probably close enough to tell you whether the HUD or Speedo is the more accurate of the two.
Posted: Thu Jun 05, 2008 2:13 pm
by clm2112
My hands are usually too slippery with grease to grab the green digits floating in the air in front of the car. Besides, they get angry when molested like that, start picketting the dashboard, flicking bugs at your back, etc.
Meanwhile, back in the real world....
I used to do the measured mile/stopwatch thing. Now I'm just lazy and use a hand-held GPS. Find a stretch of road, set cruise control, then compare the GPS velocity to the speedometer. If both are off, you can alter the multipliers in the ECM to correct the electric speedometer to match actual speed.
Posted: Thu Jun 05, 2008 2:20 pm
by Skippy1827
Posted: Thu Jun 05, 2008 4:25 pm
by bonnevillain
not till you mentioned it O.o
Posted: Thu Jun 05, 2008 5:10 pm
ROTFLMAO, now i see it, i don't have that dirty of a mind, geez
