Need some help quick
Posted: Fri May 22, 2009 10:19 pm
by 92BonnevilleSE
Re: Need some help quick
Posted: Fri May 22, 2009 11:57 pm
by Archon
Those are the return springs, and the self adjusting mechanism. They're easy to find parts at virtually any parts store. The easiest way to see how it all goes back together is to pull the drum off the other side, and compare things.
Posted: Sat May 23, 2009 12:16 am
by 92BonnevilleSE
It got to dark to pull the other side off to compare things so will have to do that in the morning. This will just affect the ABS correct?
Posted: Sat May 23, 2009 1:39 am
by bill buttermore
92BonnevilleSE wrote:It got to dark to pull the other side off to compare things so will have to do that in the morning. This will just affect the ABS correct?
These are parts of your rear service (regular) brakes. If you lose the hardware as you have, you may also lose (probably already have lost) the hydraulic portion of that brake, (rear wheel cylinder) leaving you with only front brakes that will operate with the pedal close to the floor due to loss of fluid and pressure.
Do not drive the car without repairing this damage! You may have to replace the wheel cylinder or at least install a rebuild kit for the cylinder on that wheel.
As Archon suggested, use the opposite side as an assembly guide then replace everything that is damaged including the shoes if they have become coated with brake fluid. If the drums are usable, clean them and all the parts with brake parts cleaner. Buy parts for both sides. When you have the broken side done, replace the parts on the other side. Then, you will probably need to bleed the brakes.
How to bleed brakes
Posted: Sat May 23, 2009 5:32 am
by crush
Thats my rule of thum too,
NEVER DRIVER A CAR WITH BAD BREAKS
,And always repair both sides together.This ensures they work evenly and prevents brake pull.
Posted: Sat May 23, 2009 1:35 pm
by 92BonnevilleSE
I got up first thing this morning and had to WALK to Auto Zone..lol. No big deal was only about a mile from my in-laws house so it was good exercise. Anyways, got the parts to do both back brakes and got them on and now it works great. What could of caused this to happen? Just the pieces getting to old and finally had enough?
Posted: Sat May 23, 2009 1:46 pm
More than likely. Did you just replace the cylinders and springs, or did you replace pads and shoes as well?
Posted: Sat May 23, 2009 1:49 pm
by 92BonnevilleSE
I did the cylinders and springs as well. Wasn't as hard as I thought it would be. First time I've ever changed the cylinders myself.
Posted: Sat May 23, 2009 4:11 pm
by RJolly87
It happened to me too. Only I just heard a chattering in the back. I took it to brake masters for an oil change and they found no issues, and cleared the car for a 200 mile round trip. I get to the city I am going to, the chatter has turned to a grind, and the brake pedal is getting worse and worse. I pulled back wheels off in the autozone parking lot only to find that the adjuster dropped and was stuck by the bottom portion of the shoes. I wasn't exactly happy about that. Just make sure that it is replaced with a new one <looks like it had to have been as one side is broken off, maybe accounting for the failure> as those things wear out too.
Posted: Sat May 23, 2009 7:12 pm
by 92BonnevilleSE
Yeah I got all brand new parts for both back brakes. I knew something was messed up as soon as I heard that clunk. It was nasty sounding. I was not happy when I seen those 3 pieces just fall to the ground when I got the brake drum off. Prolly the most I swore in quite a while
At least it wasn't nothing to bad and that the brakes got me at least to my destination without any problems.
