Car Alarm Issue
Posted: Wed May 20, 2009 8:01 pm
by JBMark33
So this what it does after it arms itself.
The regular horn works fine, but when i unlock and lock all the doors, it sounds just like this little "blump" noise like you hear here. Are there two horns in our cars? Maybe a fuse or relay is messed up?
Re: Car Alarm Issue
Posted: Wed May 20, 2009 8:25 pm
So, wait. Your alarm is supposed to be going off at this point? I hear what sounds like someone pounding on a snare drum with the snares turned off. Is that what I'm supposed to be listening for? Sounds like something's messed up. Does your horn work normally?
Re: Car Alarm Issue
Posted: Wed May 20, 2009 8:56 pm
by JBMark33
Yeah that little noise is my car alarm horn going off. My normal horn works fine.
Re: Car Alarm Issue
Posted: Wed May 20, 2009 9:02 pm
by harofreak00
The horn is located on the drivers side, accessible when you remove the inner fender. There is probably an aftermarket horn mounted there as well, going bad.
Re: Car Alarm Issue
Posted: Wed May 20, 2009 9:19 pm
by JBMark33
harofreak00 wrote:The horn is located on the drivers side, accessible when you remove the inner fender. There is probably an aftermarket horn mounted there as well, going bad.
So you think that an aftermarket horn was added and that it is now going bad?
Re: Car Alarm Issue
Posted: Thu May 21, 2009 10:10 am
by RookieSSei
x2 yep thats it mine does the same thing i gotta get it fixed it's on my long list of things
Re: Car Alarm Issue
Posted: Thu May 21, 2009 12:16 pm
by JBMark33
RookieSSei wrote:x2 yep thats it mine does the same thing i gotta get it fixed it's on my long list of things
I understand that there are two horns on our cars. How do I know which one is the broken one?
My regular horn works fine... so I know one of the two horns work as they should.
Re: Car Alarm Issue
Posted: Thu May 21, 2009 1:51 pm
by harofreak00
The regular horn is a 2-horn design... mounted on the same unit. Anytime you push the horn, both horns engage.
The OEM one will look OEM, and the aftermarket one will look aftermarket. If you can't tell the difference, you shouldn't be working on it.
Re: Car Alarm Issue
Posted: Thu May 21, 2009 2:04 pm
by JBMark33
Replacing the horn is not a difficult project. I am just confused in trying to troubleshoot which horn is bad.
Looking at Gumaball's picture at the beginning of this thread, are both of those horns the "double" OEM horn?
http://www.pontiacbonnevilleclub.com/fo ... orn#p97819
Re: Car Alarm Issue
Posted: Thu May 21, 2009 2:12 pm
by harofreak00
Yes
Re: Car Alarm Issue
Posted: Thu May 21, 2009 2:14 pm
by JBMark33
So do I also have an aftermarket horn added or is that your guess?
Re: Car Alarm Issue
Posted: Thu May 21, 2009 2:20 pm
by harofreak00
Thats my guess.
Enough with the questions
Just get under there and look.
Re: Car Alarm Issue
Posted: Thu May 21, 2009 2:31 pm
by JBMark33
Hey now. lol
Yeah, I am installing my shift kit tomorrow, so probably some time this weekend I will get the wheel off and the plastic shielding.
Standby.
