Suspension "float"
alec_b
- GXP Member
- Year and Trim: 1996 SSEi, Bright White, Medium Teal, 197k
Suspension "float"
I'm not sure whether this should be here, or somewhere else, but then again I'm not even sure if it's a mechanical problem.
The best way to describe it would be that above about 60, the steering gets a disconnected feel to it. It still handles OK, and I never feel like I'm not in control of the car, it just seems to get a dead spot on center where light adjustments left or right have very little or no effect.
Around town, she handles great. I love the stiffer steering compared to my cadillac or aurora. I'm almost thinking it's a tire problem, the Goodyear assurances I have on there right now aren't in the best of shape, but I was hoping to get to use them through summer because of the other work the car needs. The other thing I was thinking (that desperately need to be replaced) are the original struts/mounts with 200k on them. Could that have something to do with it also?
Thanks everyone.
Thanks everyone.
Mods: Clear corners, gutted airbox, Alpine CDA-9886. Plans: 4x SensaTracs, high-flow, FM 80, 3.5 pulley, and for gods sake some good rubber.
Bob Dillon
- Retired Gearhead
Re: Suspension "float"
A definite "maybe" on the struts. Checked your tire inflation pressures? Bump the front ones up a few pounds and see if the handling changes. Bet it will.alec_b wrote:The other thing I was thinking (that desperately need to be replaced) are the original struts/mounts with 200k on them. Could that have something to do with it also?
alec_b
- GXP Member
Tire pressure eh? I can check that for sure. I've been meaning to do it... just been busy. Which isn't really an excuse seeing as how I work at a shop.
I know, the struts are way past due. I've only had the car for a couple months, not enough time to get the cash together to get it done. I want to do all of them (sensatracs) at the same time so it's going to be ~$300, not something that really fits in my budget right now. But it's going to be done for sure.
slug
- GXP Member
- Year and Trim: 1994 SLE
1998 SE - Location: Twin Lake, MI
Check your tire widths against factory recommendations. If your tires are too wide for the car, you can get a "steamroller" feel on the highway just as you describe.
I put extra-wide tires on my Jeep XJ once, and the highway feel was atrocious. I don't know if Bonnevilles are susceptible to this as well, because I never strayed from factory recommended specs on any cars after that.
If your alignment is "toed-out" a bit, this can also cause a very uncomfortable steering feel at highway speeds. Have your alignment checked at a well-recommended alignment shop.
alec_b
- GXP Member
The tires are a factory size 225/60/16. I'm really not sure about the alignment, maybe some day I'll throw it on the rack at work. Thanks for all the suggestions!
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Monroe is having a rebate on Sensatracs right now. $80 for 4 struts. Makes it closer to $200.
alec_b
- GXP Member
Sorry, I forgot I was including mounts in that too.
Does the price at RA reflect the rebate at checkout? I knew sensa's were on sale, we have a sign up at work about it. Funny you mention it, I was just looking at it the other day.
LeSabre in Buffalo
No, it doesn't. It's an old-fashioned snail-mail rebate.
Using the discount code knocks $12-13 off the price. So it's not too bad for 4 struts shipped.
alec_b
- GXP Member
Yea I double checked, with shipping from 2 locations, with KYB mounts and the rebate, it was $270 ish.
Thanks for the tip!
Thanks for the tip!
LeSabre in Buffalo
No problem!
