abs and trac controll
Posted: Tue Mar 31, 2009 2:39 pm
by 00superchargedSe
First i started it and the abs light had came on. Then today i started it and the trac- controll came on. I know there is a sensor that connects to the wheel hub. If that is what is wrong, then what is a good price to replace it.
Re: abs and trac controll
Posted: Tue Mar 31, 2009 2:41 pm
by harofreak00
Check the wiring that goes to all 4 hubs. Take the connector off and inspect the terminals for corrosion.
Posted: Tue Mar 31, 2009 3:10 pm
by sco99888
check the fuse,i had same problem fuse was blown.
Posted: Tue Mar 31, 2009 10:12 pm
by laxmangl
when you check the sensors, spray some electrical parts cleaner on them. Worked great for me.
Posted: Wed Apr 01, 2009 7:46 pm
by 00superchargedSe
took the sensors off and spayed them down. lights still on and also the low-tire pressure light. What next ??
Posted: Wed Apr 01, 2009 8:08 pm
by harofreak00
You didn't find any corrosion on any of the hubs?
Posted: Thu Apr 02, 2009 12:48 am
by 00superchargedSe
no. they were fairly clean. some guy i was talking to said that it could be a wheel speed sensor ?? idk
Posted: Thu Apr 02, 2009 10:43 am
by Archon
It's a rather low level signal, the cleaner the connection, the better. Did they seem good and tight? If everything looks and feels good, then it is likely the wheel speed sensor has gone bad. You'll have to take it someplace that has a scanner that can read which wheel has the problem. Intense sells a good hub for around $100.
Posted: Mon Apr 13, 2009 9:22 pm
by 00superchargedSe
i had a scaned by a friend and it said the right rear sensor. How much is a fair price for a rear hub?
Posted: Mon Apr 13, 2009 11:20 pm
by Archon
The rear hubs are more expensive than the fronts. RockAuto has decent prices, and Timken makes a good hub. I'd suggest not to just look for cheap, as they seem to use wheel speed sensors of lesser quality that may only last a few months, and you'll be right back to the same problem.
Posted: Mon Apr 27, 2009 5:20 pm
by 01bonneSC
00superchargedSe wrote:i had a scaned by a friend and it said the right rear sensor. How much is a fair price for a rear hub?
There was another post about the whole rear ABS/WSS harness corroding and needs replacement of the whole thing. I know Haro had to do it on his. What im saying is it may not just be the hub.
Here it is....
viewtopic.php?f=18&t=10671
