What did you do to your car today?
haro1225
Year and Trim: 2004 GTO
Re: What did you do to your car today?
Post by haro1225 »
Today was gonna be the day I put insurance back on the 04 and bring it out. NOPE! I had new sway bar bushings and I went to install those and the front ones are way too big. Did the rears as those were correct, but I opened a can of worms by doing that. Not from the bushings but because of a wheel stud that had been stripped on the rear so I decided to replace that, which meant removing the brake upon which I did the one brake pad came off in two pieces. So I ordered new rear pads and rotors and now it's all apart waiting for more parts.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
desertpierat
Post by desertpierat »
Installed a sway bar from a GXP and a new dimmer switch to stop the random flashing of my lights. Tomorrow onto the coil packs and finish sanding/buffing my headlamps.
2000 Pontiac Bonneville SSEi
2010 GMC Acadia SLT2 (wife's car)
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Post by MattStrike »
Did a lot of stuff today. Changed the oil on the Saab, changed the oil on the Camaro, and I finally fixed the trans mount on it again:
Don't worry, it's a temporary fix while I source a parts car for the inevitable 6-speed swap. Better than the C-clamp I found there when I bought it. I guess now I fit in with the F-body peoples.
Other things include replacing the thermostat on the '89 (and I didn't break the thermostat cover!) that turned into pulling the valve cover to fix the PCV tube seal and replacing some rotted vac lines. Then I got the garage cleaned up from all the winter maintenance.
CMNTMXR57
Post by CMNTMXR57 »
Do I dare ask how a C-Clamp worked??
Anyway, did 100,000 mile servicing on the Impala today. Well technically 101k since I did it last at 98k. Next step will be plugs, wires, and a cooling system flush.
2011 Camaro SS
MattStrike
'92 Trofeo
The tail housing on this trans, the one bolt broke off in the housing. So there is only one bolt holding the trans to the mount. The C-clamp was doing something for that I think. I've gone through two mounts myself now. It's annoying because I welded a bracket to the upper mount steel piece that goes to a bolt boss on the side of the trans case to make up for the un-useable boss (twice...). *shoot* aftermarket parts that can't hold down the power of a stock 3800 or ratchet strap? Yeah, whatever it takes.
1oldman
Post by 1oldman »
Had a 4 wheel alignment on the 2005 SE because after 2 weeks, finally finished installing the rear air shocks and shock mounts. - BC
SSnake
Year and Trim: 2001 grand am gt
Post by SSnake »
This probably is the most boring thing in this thread, but I got my first drivers license with it! It hasn't passed inspection until now and last time I took the test, a coolant hose came unclamped just short of finishing the test.
1oldman
Post by 1oldman »
SSnake wrote:This probably is the most boring thing in this thread, but I got my first drivers license with it! It hasn't passed inspection until now and last time I took the test, a coolant hose came unclamped just short of finishing the test.
Ain't that just the way things happen? Glad you have your NDDL now and you joined us. - BC
haro1225
Post by haro1225 »
Today I finished up the 04 with the exception of drilling slots into the struts for alignment purposes. I also discovered that the wheel bearing on the front is bad. :banghead: This is especially bad because of the longer studs to fit the brembos. Some aftermarket hubs have different knurl sizes so this will complicate things even more. At this rate I'm never gonna be able to drive it this year. Another week of driving the beater. :thumbdown:
-Ryan
djdani3l10
Year and Trim: 2005 Pontiac Bonneville SE
Post by djdani3l10 »
my ac compressor went yesterday, so i decided to go to a scrap yard to look for the part.
and in hamilton it is RARE to find a bonneville in a scrap yard.
today i found one.
this bonneville had a ton of new parts put into it (including an ac compressor) so i picked that up for 45$ cad.
saved myself alot of money with this find.
cant wait to buy more.
2000Silverbullet
Post by 2000Silverbullet »
I watched metal particles draining out of my transmission case
I have two new trophies a worn-out fourth gear shaft and a worn-out oil pump shaft
I refuse to keep the fragged torque converter.
I also terminated connections for the new harness to the Pioneer head unit
MattStrike
'92 Trofeo
I built a sealed stealth 10" subwoofer box for my Camaro, then built an amp rack, and bolted it all in and wired it up. It sounds a lot better now, previously all it had were the tiny front door and rear pillar speakers and I'd added rear deck speakers as part of the interior swap, nothing appreciable below the 500hz level of sound. Now that I have the sub in I ended up disconnecting the rear pillar speakers, they were supposed to be some sort of 6" subwoofer but they were trashed. The rest of the speakers are some nicer Polk speakers that are being driven by a stock 7-band EQ head unit. Overall the sound quality is much better now.
CMNTMXR57
Post by CMNTMXR57 »
Friday evening, figuring I was going to be down at my other house working, I checked the forecast for the next week and half, figuring that we're past accumulating snows since we nearly into April, and there was nothing on there. So on Saturday I turned down my torsion bars and took the plow receivers off.
Then last night, got back on Intellicast, checked again, and ;safd;dafhnkdsf, wouldn't you have it, next Monday 3 - 5 inches, and Tuesday 1 - 3.
Now it's back to nothing next Monday, but still maddening nonetheless.
2011 Camaro SS
Increased my tire pressure from 30psi to 35psi. Not sure if I'm delusional, but the car drives straight at 35psi, but not at 30.... LOL
2000Silverbullet
Replace the steering intermediate shaft with a new design unit.
RockAuto FTW!
2000Silverbullet
Added an antennae signal strength booster.
*dang*, Paul.. Your car is getting like a spa treatment since that trans chunked itself. Hahaha.
2000Silverbullet
Haha that's cause I priced out three potential equivalent replacements.
Better the devil you know...... And after 16 years she deserves a spa treatment.
Don't tell my wife that!
2000Silverbullet
Son of a xxxxx! Now I have to replace the radiator and aux tranny cooler!! Sparkles are not clearing up!! *dang*!!
The good news is the tranny rebuild is almost done......as is my budget!
I never learn......should have scrapped it. :dontknow:
1oldman
Post by 1oldman »
2000Silverbullet wrote:Haha that's cause I priced out three potential equivalent replacements.
Mine told me the same thing. I got lucky and was able to get Matt to take mine off my hands. - BC
