Page 3 of 3
Re: Bonneville and massive error
Posted: Sat Sep 08, 2018 9:40 pm
by 95naSTA
So I read my 95's FSM on fueling thinking the basic concept will be the same. One thing that I didn't really know what that when the evaporator system is purging it says the INT could be as low as 90. But, the engine must be running in closed loop for the EVAP to be on. I'm assuming your 90 has an EVAP system.. It might not.
One thing you may want to double check is continuity of the wire going from the PCM to the O2 sensor. I'm pretty sure you just have a one wire O2 sensor. If it's grounding out intermittently, that could explain a lot.
Posted: Sun Sep 09, 2018 3:23 am
by Karpov
Yes i have one wire o2. Ex owner had 10 years ago grounding problems with sensor because one exhaust manifold bolt was missing.
Posted: Sun Sep 09, 2018 10:41 am
by 96 SSEi
unplug the o2 sensor for test run - more fuuel consumption but should run fine if o2 is issue
Posted: Sun Sep 09, 2018 11:09 am
by Karpov
Can someone check what int and blm is when revving 4000rpm on idle? Or maf mg count?
