Re: '99 SE stalls and dies at low speeds and idle
Posted: Sun Jul 22, 2012 1:12 pm
Hey 1oldman,
I only put seafoam into the gas tank. I didn't seafoam the rest of the car.
How hard is it to take the TB out? There seem to be a lot of bolts on the sides and under it. The throttle cable also seems confusing to remove. Would I be able to just disconnect the intake air piping and clean the TB from that angle? Moving the butterfly valve a bit to clean around it?
EDIT:
As a sanity check, I pulled out the MAF sensor since the error code still reads P0102. I cleaned it up all nice and purrty. The filament went from being brownish to white. Driving around, the far feels happier. It doesn't "put put put" as hard when putting it into reverse. The car does not stall nearly as much. It mostly seems to stall when you cruise (foot off break and gas) for an extended period of time. For example, get the car up to 35-40mph. Take foot off gas and let the car move forward. The RPMs drop, go below 800-1000, keep falling and with the car not attempting to recover them drops to 0. All times though, a little bit of gas and the car happily idles at 800-1000 rpm. If the car does stall, and you try to key the car on the car will die again unless you apply some gas in neutral until the battery gauge goes up a bit.
Next weekend I will probably buy a new multimeter (mine is at my mom's apartment in NY) and check that all the sensors are working fine.
-robodude666
EDIT:
-robodude666
